want to tuck all 4 wheels..
Old Jan 25, 2009 | 11:58 AM
EJ8CIVIC's Avatar
Default want to tuck all 4 wheels..
this is for my 91 crx hx
ok i had order off ebay the yellow neuspeed springs for my crx..they didnt even lower it..so they are for sale..and they are just setting in a box as of now
im looking to do a wheel tuck..not a huge tuck where im setting on the ground, just like i mild like where the wheels tuck bout inch in the fender wells..
can someone led me to some good springs?
Old Jan 25, 2009 | 12:01 PM
EE2bitsk's Avatar
Default Re: want to tuck all 4 wheels..
get some koni yellow struts and ground control coilovers and gc top hats.
Old Jan 25, 2009 | 12:09 PM
Andrew-L's Avatar
i have the neuspeed yellow springs on my hatch, didnt drop it a bit, but it rides alot better than stocks
Old Jan 25, 2009 | 12:11 PM
low91rex's Avatar
You probably want some coilovers because they are adjustable and you can set them as low as you want. I had GC's on my crx for a while and they were niiice.
EF-8SiR's Avatar
Just having strictly springs won't do the trick. I'm assuming price is a factor, go with a coilover/lowering spring package, and/or adjustable shocks such as - http://cgi.ebay.ca/88-91-HONDA-CRX-C...1%7C240%3A1318
Skunk2 adjustable coilover setup is what im currently using, it works great and the struts that i've matched up can take a beating, from my experience.. you can't go wrong with these - http://www.skunk2.com/mm5/merchant.m...de=517-05-0740
(320$)
Old Jan 25, 2009 | 12:44 PM
EE2bitsk's Avatar
if you really wanna spend as little as possible, i would say just get some sleeve coilovers like GC or skunk2, then put them on your stock struts and have someone who can weld take your stock top hats and cut them and extend them about an inch and then you should be alright to lower the car a lot and not blow the struts since you will have the extended top hats.
Old Jan 25, 2009 | 02:37 PM
xci_ed6's Avatar
My k-sports go low. Very low. They ride very rough though.
Old Jan 25, 2009 | 02:45 PM
EFinawesomeman's Avatar
If you are looking for REALLY cheap. Cut your springs. It's a terrible ride but you can slam the shizz out of your car. I wouldn't recommend it though.
Old Jan 25, 2009 | 02:58 PM
xfrankx's Avatar
there are springs out there that will lower your car 2.5in or even 3. that should be good to give you some tuck. mine tucks like that and thats what mine is dropped
Old Jan 25, 2009 | 03:17 PM
lilsicsoul's Avatar
Skunk 2 coils...
Old Jan 25, 2009 | 04:13 PM
GroundZer0 336's Avatar
if you want springs sprint makes some good ones that lower 3" or 3.5 or something. you could always get some crap ebay sleeve coilovers and flip the spring perches on your struts.
Old Jan 25, 2009 | 04:30 PM
EJ8CIVIC's Avatar
yea cash of the think right now...i have the neuspeeds ill try for the sprint springs...if some1s intrestead..
i know i have that ebay in my watch profile..lol....im just trying to get ppls differ opinoins
Old Jan 25, 2009 | 04:43 PM
My skunk2 springs gave it a reeeaal clean drop. I'm not tucking and I have 16's. But it is a good drop and comfy ride.
Old Jan 25, 2009 | 04:47 PM
xci_ed6's Avatar
I'll get better pictures tomorrow, but this is K-sports at the HIGHEST. They go down another 7cm easy. I dropped them almost all the way one day (about 10mm left at the strut) and the front tires were mm's from from the frame rail.
Old Jan 25, 2009 | 04:56 PM
BiGZ's Avatar
my 88 with GC'z + 15" bladez/205/50 tirez (not even all the way down,about middle)
Hate speedbumpz though,hah!
Old Jan 25, 2009 | 05:01 PM
ed8_dx's Avatar
You must have put your spring on wrong or something, I have the Nuespeed race springs (yellow) and they lower the front 2.25 inches, and the rear 2.0 inches. Also are you sure you got the Nuespeed springs, there are a set of yellow springs on there, that claim to be the Nuespeed springs but are junk.
Old Jan 25, 2009 | 05:03 PM
Stock springs painted yellow. I heard that about other springs too.
Old Jan 25, 2009 | 05:11 PM
ed8_dx's Avatar
Yep, thats what they are doing, your "Nuespeed" springs should be physically shorter than the stock ones, and wound tighter also.
Old Jan 25, 2009 | 05:51 PM
hushypushy's Avatar
Ground Controls + either Tokico Illuminas or Koni Yellows
Ajdustable ride height and shock dampening, lifetime warranty on both shocks, and the Ground Controls go low enough to tuck a little tire.
I'm almost down to the bottom in the back...there's at least an inch more up front. Keep in mind I'm running 185/60/14's
Old Jan 25, 2009 | 05:55 PM
hai_tech's Avatar
D2 racing
Old Jan 25, 2009 | 05:56 PM
TOUGE4LIFE's Avatar
NO LEGS
wow,200$ shipping on those. otherwise its a great deal.
If I were short on cash but had to spend money on lowering my car. I would go with a set of H&R Race springs. they give a decent drop, (around 2.5 inches?) and they ride nice. Paired with a set of Koni yellows they make a good track set up as well.
Old Jan 25, 2009 | 06:15 PM
stankcrx's Avatar
ya ive had the nuespeed race springs b4 and def a good drop fits perfect in my opinoin and very good stiff ride
Old Jan 25, 2009 | 06:32 PM
EJ8CIVIC's Avatar
ed8
i did put them on right...can u send me a pic bro...at first i up thewords upside down that didnt wrk then right side up and it look the same
ill post pics of my spring 2morro...
Old Jan 25, 2009 | 06:35 PM
teggsr925's Avatar
tuckin 4 wheels could mean wheel fitment problems in the back. rarely do i see the rears tucked on crx's. and i definitely would recommend against just springs. u will need a coilover to be that low. good struts/shocks and a adjustable spring could work too
Old Jan 25, 2009 | 07:34 PM
ed8_dx's Avatar
Originally Posted by EJ8CIVIC
ed8
Yeah, I just wanted to make sure, I am a mechanic at a Honda dealership, and you wouldn't believe how many times kids come in asking about lowering springs they bought and they didn't lower it, usually due to them being installed backwards/upside down etc. I will dig up a pic for you tonite, or first thing in the morning, my rex is completely stripped at the moment, but I will find you one.
