fabbing up new ss mani for my drag car
Old Jan 25, 2009 | 11:30 AM
Garage 808 Hatch's Avatar
Default fabbing up new ss mani for my drag car
The owner of Garage 808 and I are fabbing up my new manifold. SCH 40 SS 1 1/2". Its going in a CRX with a BW S372r and dual tial 44's. looking for some input and criticism
Old Jan 25, 2009 | 05:03 PM
JDM JEFFREY's Avatar
Default Re: fabbing up new ss mani for my drag car
lookin good homie
Old Jan 25, 2009 | 07:51 PM
90blackcrx's Avatar
Pretty hard to tell anything from the pics. Are you building a divided manifold, it looks like the cylinder pairing is wrong. I also would of tried to get the wastegates closer to collector.
Old Jan 25, 2009 | 09:42 PM
91jdmhatchback's Avatar
cly. pairing looks right to me. 1-4 goes to the front side, and 2-3 goes to the back side.
in for finished pics. And more detailed pics to.
Old Jan 25, 2009 | 10:18 PM
hondalover91crx's Avatar
id have to agree i dont really like the wastegate placement. i mean i know space is tight but trying to merge your wastegates in at that angle to the 2 collectors is not going to work as well as youd think. you expecting exhaust gases to flow in the opposite direction of the path that its flowing. air doesnt make sharp turns unless you influence it. i understand this is a drag car and its not really important to you to be able to keep the boost low but still its very inefficient. any reason why your running twinscroll? how much power are you looking to make and what times are you aiming for?
Old Jan 26, 2009 | 02:57 PM
m R g S r's Avatar
If that is a twin scroll (looks like it) then the pairing does look off.
And why didn't you use thin wall if its a drag car?
Old Jan 26, 2009 | 03:04 PM
the pairing is not off you tools. am i the only one seeing it is fine?
As long as 1-4 and 2-3 go into the same side, it's fine.
Old Jan 26, 2009 | 03:12 PM
m R g S r's Avatar
2+3 are going into the top "half" of the collector. That part of the collector is not paired.
This is how it's supposed to be.
Old Jan 26, 2009 | 03:15 PM
m R g S r's Avatar
sorry im blind i thought the runner all the way to the right was actually on the third exhaust port. sorry!
Old Jan 26, 2009 | 03:23 PM
haha, i was woundering what was going on there. i let this slide sense your blind....
Old Jan 26, 2009 | 03:27 PM
ToxicFabrication's Avatar
OG Fabricator
looking really nice, more pics please!
Old Jan 26, 2009 | 03:32 PM
redboost10's Avatar
so the wg elbows are just coming off 1/2 of part of the divided collector? they are not within the joining of the two pipes? i cant really tell.
Old Jan 26, 2009 | 03:42 PM
the wastegates come off of the different sides. it is a divided manifold, 1 and 4 go to the front and 2-3 to the rear. the WG elbows are after the 2 pipes merge. i will hav updated pics tonight
Old Jan 26, 2009 | 03:47 PM
redboost10's Avatar
is this car going to be done for this year graig?
Old Jan 26, 2009 | 05:25 PM
Trying damn hard to make that happen
Old Jan 26, 2009 | 06:04 PM
90blackcrx's Avatar
Its hard to tell from the pics actually. I thought the same.
Old Jan 26, 2009 | 06:13 PM
DESTROYER's Avatar
do work son!
Old Jan 26, 2009 | 07:07 PM
we will be changing the routing of runner 3. it'll drop out and under runner 1, then into the collector
Collector from front of car
collector from top
mani from pass side
mani from top driverside view
Old Jan 26, 2009 | 07:11 PM
OG Fabricator
i really like it minus the waste gate set up. looks really nice, love the routing of the piping
Old Jan 26, 2009 | 07:35 PM
ya, we were really limited as to where to put the gates, where they are at now, the just fit under the fiberglass front end.
Old Jan 26, 2009 | 09:09 PM
m R g S r's Avatar
that manifold looks very heavy for a drag car. like i said previously, why didn't you use thin wall tube? looks like you have plenty of room to run braces to support the turbo.
just a thought.
Old Jan 26, 2009 | 09:13 PM
redboost10's Avatar
looks good graig. tell james to hurry up and finish it. is he doing the welding?
Old Jan 26, 2009 | 09:19 PM
I went with heavier material for strength and weight. the car was very close to the min weight for the class i want to run, and weight out over the front is good. i realize i could have just added weight in the traction bar or frame horns.
yes, james is doing the welding. we will be re-doing the #3 runner friday, and then he should be welding it soon, after that the DP and dumps will be fabbed, and then the new charge piping
Old Jan 27, 2009 | 05:25 PM
speeddave's Avatar
looks sick! make sure to post up some more progress pics, i want to see how it turns out.
Old Jan 27, 2009 | 06:12 PM
tell James to get his car done too
looks hot homie
