Accesory wire color from ignition harness?
98 CL2.3
i know which one it is from the back of my radio.. you think its the same at the ignition? who knows what color it is?
or another place besides the ignition harness that i could reach it?
Get a multimeter, they are cheap about $20. With the key off find the battery wires, they are 12 volts. Mark them as such. Then put the key in and turn all the way forward to RUN. Find a wire that is 12 volts, when you start the car when testing it will turn off temporarily.
The battery wire should be white, the starter wire should be black with a white stripe, the Ignition wire should be black with a yellow stripe, the wire you want ACCESSORY should be yellow. ALL OF THESE WIRES SHOULD BE VERY THICK. TEST ALL YOUR WIRES!!!!! DON'T SET OFF YOUR AIR BAG BY TESTING YELLOW OR ORANGE SLEEVED WIRING!!!
Full Race A6
Audio / Security / Video
Jun 12, 2004 05:04 AM
