crx front bumper on hatch
im not new to this site and im not a friggin ricer, searched around a bit and im just wondering if a 88-89 crx front bumper and support will fit on a 90-91 hatch...has anyone tried it?
or will any crx bumper fit on any civic chassis...with the support?
Me too, we been discussing it for a while. Wanted to see if it'll fit without using crx fenders. Also delete the civic front filler piece all together for the cleaner look.
im not 100% on this but ive looked into it. from what i have heard if you must use the crx fenders you have to use a hatch fender and cut and weld it onto the rex fender at the bottom to get rid of the black piece. if you can in fact use a crx hood and front bumper and keep the front hatch fenders then im doing it. i wanna see proof before i go grab it from the junk yard though
The hoods are the same, to do a usdm->usdm swap you need:
bumper cover
bumper absorber
bumper beam
bumper beam mounts
fenders
fender/bumper brackets
corner lights
This is for CRX front on a hatch, for a hatch front on a CRX you also need the bumper filler.
I had a 91 CRX and a 91 hatch and I swapped front ends for awhile. As was stated, the CRX fender has the black plastic lower stuff, so does the bumper, and that wont look right w/o more work.
bumper cover
bumper absorber
bumper beam
bumper beam mounts
fenders
corner lights
I dont get it, why would we need fenders when sticking with the hatch corners? After looking at cbe front end and the crx, where the bumper meet up the fender, that appear to fit.
the only thing thats gonna be work is the fixing of the hatch fenders to work to get rid of the bottom crx piece. but if its a track only setup then who cares what it looks like if weight is your only concern
ok i dont under stand what the fenders matter im concerned with the corner light area wher the bumper mates up with the fender. if they are close to the same length it will bolt on. thats what im asking?
a bigger pic of that would help. loldont get it twisted. the only reason i asked this was because the cars painted and I dont want to cut the fender. I was just asking if the bumper cover would actuallt bolt on....with a HF support
isnt it different where it meets the fender and corner light though.
i used the hood fenders bumper bumper support radiator t bar headlights and modified the lil filler pieces between the door and wheel
