Timing Belt Tensioner
Old Jan 24, 2009 | 07:40 PM
zeplin's Avatar
Default Timing Belt Tensioner
Is the timing belt tensioner on the D15B7 engine spring loaded or nitro charged? I think my timing belt has slipped, and I'm trying to figure out if perhaps the spring has worn out before I tear it all apart.
Thanks in advance!
Old Jan 24, 2009 | 08:30 PM
iamthefollower's Avatar
Default Re: Timing Belt Tensioner
If i'm not mistaking I'm pretty sure it's spring loaded...
Old Jan 25, 2009 | 07:44 AM
honda.lioness's Avatar
It is spring loaded. See http://www.bkhondaparts.com/billkay/...temcomp=Engine
I do not think the spring does anything once the tensioner is tightened down (a step that is part of the TB change and tension setting procedure). If for whatever reason the tension does not seem to be holding, you should start by re-setting the tension per http://media.honda.co.uk/car/owner/m...l/pdf/6-20.pdf . Then check the timing.
Is the TB overdue for a change? They do stretch and can lose tension.
Jeffrego
Honda Civic (2001 - 2005)
Oct 31, 2018 05:02 AM
Lambo123
Sep 7, 2009 10:25 AM
GsDAteg
Aug 6, 2007 07:52 PM
timlush
Jan 9, 2007 04:22 PM
ElectronSi
Dec 29, 2004 07:06 PM
