91 Accord LX Vibrates
Old Jan 24, 2009 | 07:04 PM
mcalvelloxx's Avatar
Default 91 Accord LX Vibrates
Hi,
My accord vibrates at idle and it's pretty annoying.
I searched the forum and saw that I should clean my IACV.
I located it, unscrewed the bolts but can't get it out...the hoses are so old.
The screen of the IACV is definitely clogged.
I obviously need to fully remove the part to clean it out, correct?
Thanks!
Old Jan 24, 2009 | 07:09 PM
P_Adams's Avatar
Default Re: 91 Accord LX Vibrates
Originally Posted by mcalvelloxx
Hi,
Thanks!
Here's some information which will get you going, courtesy of the guys from FAQ's
https://honda-tech.com/forums/honda-accord-1990-2002-2/cleaning-iacv-fitv-tb-1844067/
Are you dealing with the normal 4 banger blurred vision vibrations, or is this the teeth rattling - parts falling off type?
You may be dealing with another issue.
P
Old Jan 24, 2009 | 07:42 PM
https://honda-tech.com/forums/showthread.php?t=1844067
P
Thank you!
I dont think is the "parts falling off type."
The steering wheel and dashboard vibrate.
Once I slightly hit the gas, the vibrations are gone. At idle, they start again.
The IAVC is clogged but, like I sad, I can't get the hoses out :/
Old Jan 24, 2009 | 07:46 PM
hondafab19's Avatar
or maybe is your car just idling a little low??
if so adjust it up a bit...
Old Jan 24, 2009 | 08:47 PM
ap716's Avatar
can also be worn out motor mounts
Old Jan 24, 2009 | 09:02 PM
Yeah, a mechanic did say I need motor mounts. Will take care of that ASAP.
But should I clean the IACV and adjust the FITV?
Old Jan 25, 2009 | 05:12 AM
P_Adams's Avatar
If your idle wanders and has difficulty maintaining 700rpm, then I would say yes. The stiff, brittle hoses can be problamatic, so be careful you don't "break yourself into a corner"
Is this an Automatic, or a Standard Transmission.??
P
Old Jan 25, 2009 | 06:51 AM
It's standard.
Yeah, when the car idles it sometimes feels like it's going to die.
Some people cleaned the ICAV without unplugging the two hoses.
I guess they only cleaned the two holes.
Is that OK to do?
Old Jan 25, 2009 | 08:37 AM
masterkill455's Avatar
yeah, thats fine. Im telling you tho, those bad motor mounts have alot to do with this
gatormeup
Oct 30, 2011 04:35 AM
gumbysix
Acura TL, RL & ZDX
Sep 10, 2005 11:31 AM
JDMwgn
Apr 8, 2004 08:13 AM
Phreaxer
Jul 18, 2003 06:44 AM
