wilwood brake kit, 11.00” or 12.19 ?
Old Jan 24, 2009 | 06:38 PM
KRock459's Avatar
Default wilwood brake kit, 11.00” or 12.19 ?
I am looking at purchasing a Wilwood front brake kit for a 91 CRX, I am running 00' Civic Si rims. Would the 12.19" rotor and caliper fit using the 15" Si rims, or is the 11" rotor the ticket? I have read others posts using the 12.19" but they all seem to be using 16-17" rims. Any advice would help.
Thanks
Kirk R
Old Jan 24, 2009 | 08:15 PM
efjones9's Avatar
Default Re: wilwood brake kit, 11.00” or 12.19 ?
i think 11 is the biggest u could go just talkn outta ma ***..jus bumping it cuz im curious
Old Jan 24, 2009 | 08:36 PM
Red_ED8's Avatar
Whats the purpose of the car? Will there be any track action in this car or just a daily? if its a daily I wouldn't waste the money (on either for that matter).
Old Jan 24, 2009 | 08:38 PM
425_Booster's Avatar
Ive looked at those too and Im pretty sure you have to run a min of 16'' for 11'' rotor and 17" for 12.19'' rotor. Should also say minimum on their site.....?
K20EF8's Avatar
11 inch, 12.19 you will need a 16/17 inch wheel, which in turn will add more weight. You dont need anything more than 11 inch
Old Jan 24, 2009 | 08:51 PM
Wilky's Avatar
I am fairly certain that you would not be able to rock either of those kits with the Si rims. Not enough clearance. There are several 15" rims that the 11" kit will work with, though - Team Dynamics being one.
Old Jan 24, 2009 | 09:20 PM
ucc crx's Avatar
i have the 11 kit on my crx and just fit under my 15 rota circuit 8's.
Old Jan 25, 2009 | 10:08 AM
KRock459's Avatar
Daily driver. I may save my $$ and do a GSR rotor/spindle/booster swap. It wont see any track time. I plan on doing a rear disc conversion as well, GSR rotors and calipers F/R should be good improvement (?)
Kirk R
Old Jan 25, 2009 | 11:52 AM
Red_ED8's Avatar
For a street car a integra brake upgrade will be great upgrade , gets my vote.
Old Jan 25, 2009 | 11:55 AM
CRX Toad's Avatar
X2 check the FAQ for the write up
Old Jan 25, 2009 | 12:13 PM
BiG Chris's Avatar
This was my last crx with the wilwood 11" kit and 16" rota's you could fit some 15's but it really depended on the offset and i dont think the OEMs fit
Weel
Suspension & Brakes
May 26, 2009 11:01 AM
thaiphob
Oct 22, 2005 12:29 AM
thaiphob
Oct 21, 2005 12:36 PM
ramz7887
Dec 19, 2004 07:50 PM
