b20 90 da swap help
Old Jan 24, 2009 | 05:51 PM
kurs's Avatar
Default b20 90 da swap help
will the intake cam being off one tooth make my b20 not start. it started and just kinda sputtered for 3 seconds and it makes a bubling out the exhaust type noise when its crainking. the green clip is the thermostat that i need to extend from back of block to thermostat housing? What are those other two prong clips for the back off the block off the b18a1 and there not on the b20? important? also my ecu wont flash any codes. Does it need to start and run for a minute before it will recognize a problem
Old Jan 24, 2009 | 06:05 PM
j_bizach's Avatar
Default Re: b20 90 da swap help
Y do you ask by one tooth, is it off by one tooth. Yes ur timing needs to be exact or even if it does run ur motor will suffer. Yes ur motor need to start and run for the obd to reconize a problem. I dunno about the other stuff
Old Jan 25, 2009 | 11:37 AM
kurs's Avatar
well i beleive hmotors online sent me the motor 180 degrees off. i now have the timing set. the car still will not start. cranks over and starts rough for 1 second and dies. i am at a loss
Old Jan 25, 2009 | 12:10 PM
kurs's Avatar
i have checked all the sensors, clips, hoses, wires and the car is hooked up. why cant i get it to start? fires but will not run no matter what i do?????????????????
Old Jan 25, 2009 | 12:27 PM
kurs's Avatar
when the number one piston is tdc my rotor in the dizzy is pointed at the number 2 wire. is that right?
DC2Terror
Jan 22, 2013 04:43 PM
eric1180
Feb 13, 2010 11:14 PM
SIC_jdm_da9
Nov 9, 2007 11:44 PM
4EvaLow
Oct 15, 2007 10:06 PM
