1988 honda accord lx won't start
Old Jan 24, 2009 | 05:25 PM
youceffhasacar's Avatar
New User
Default 1988 honda accord lx won't start
hi my car won't start, I changed the battery cable and now the car doesn't react when i put the keys in the ignition, like no lights on the dashboard and no ignition. the battery is fine, we even tried a jump start but it didn't work. I'd appreciate help on this one cuz a car that won't even start is one of the most frustrating thing I've come across.
Thanks
Old Jan 24, 2009 | 06:29 PM
P_Adams's Avatar
Default Re: 1988 honda accord lx won't start
Thanks
Is anything at all lighting up?
Which battery cable did you replace?
P
Old Jan 24, 2009 | 07:17 PM
New User
hey thanks for the reply,
I changed the positive battery cable. Nothing is lighting up, nothing whatsoever. At this point I'm thinking of calling my insurance company and see if they can tow this to a mechanic. I just want to know if there's anything i can do to fix this, at least temporarily.
Thanks
Old Jan 24, 2009 | 07:23 PM
P_Adams's Avatar
Thanks
You have two Fuse Boxes, one of these located on the right fender (under the hood) I believe.
Inside it there are several large fuses (some 50A), one marked "batt". I suspect it may have blown.
It would cut off all power. Check that first
P
Old Jan 25, 2009 | 08:41 AM
masterkill455's Avatar
yeah and MAKE SURE when you replace that battery cable you got a good tight connection on the starter and all the wires are hooked back up where they need to go. other then that, check the negative cable. Has to be clean and tight on the battery and on the engine block.
Leighlee
Honda Accord (2013 - 2015)
Oct 14, 2019 02:48 PM
boomhower80
Jun 27, 2016 01:31 AM
David1946
Nov 7, 2012 01:09 PM
layzie21
May 5, 2009 09:30 PM
HonduceChk22
Jan 29, 2009 12:27 PM
