swap from 1.5 to 1.5 v tech
VtecH = phone
VTEC
( Variable Valve Timing and Electronic Lift Control ) is a valvetrain system developed by Honda to improve the volumetric efficiency of a four-stroke internal combustion engine . This system uses two camshaft profiles and electronically selects between the profiles. It was invented by Honda R&D engineer Ikuo Kajitani. [ 1 ] It can be said that VTEC, the original Honda variable valve control system, originated from REV (Revolution-modulated valve control) introduced on the CBR400 in 1983 known as HYPER VTEC. [ 2 ] VTEC was the first system of its kind, though other variable valve timing and lift control systems have been produced by other manufacturers ( MIVEC from Mitsubishi , VVTL-i from Toyota , VarioCam Plus from Porsche , VVL from Nissan , etc).
wikipedia.org
VTEC
wikipedia.org
so do i need a wing harnss i dont have one is it still just a straight swap with out a wiring harnedd that what i needing to know and if not what wires go where and to what??
