help window wont roll up
Old Jan 24, 2009 | 12:48 PM
H.'s Avatar
H.
Default help window wont roll up
well my passanger side window on my integra wont roll up its an auto window roll up, checked the fuses and they look to be fine anyone know what might be wrong ?
Old Jan 24, 2009 | 01:16 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: help window wont roll up
I assume that it is not cold by your location. Does it try to move? Both control switches must work for the passenger window to operate.
Is there a window module installed on your alarm?
Old Jan 24, 2009 | 01:25 PM
H.'s Avatar
H.
nope its actually really sunny never cold around here , and it wont try to move at all, before it stop working it moved up but it hesitated and it went really slow, like it was struggling then one day it stop working. The driver side one works, and there isnt a window module installed on my alarm
Old Jan 24, 2009 | 01:29 PM
Dogginator's Avatar
Daisy... Daisy...
You could have a bad window regulator. You'll need to pull the passenger side door lining. Check for 12VDC delivery to the window motor. If it is getting power, the regulator or motor is the likely culprit. Try greasing the regulator mechanism if this is the case. If no 12VDC is delivered, the window switches or module (driver side) are the most likely culprits.
Old Jan 24, 2009 | 01:31 PM
H.'s Avatar
H.
ok thanks
Old Jan 24, 2009 | 04:51 PM
G Rabbitt's Avatar
I've got a window motor & regulator sitting in my basement if you need one.
civicSlut
Apr 18, 2004 10:16 AM
gUEv
Jan 22, 2002 07:59 PM
