should i go obd1 on my 01 integra GSR
Old Jan 24, 2009 | 07:45 AM
oramac_eg's Avatar
Icon2 should i go obd1 on my 01 integra GSR
ok bought a salvaged 01 GSR cant get the mirrors, windows, sunroof to work cant seem to find the problem so i been thinking about just going obd1 on the car should i do it or try and try fixing the problem ?
has anyone had this problem ?
Old Jan 24, 2009 | 08:59 AM
frost_0ne's Avatar
Default Re: should i go obd1 on my 01 integra GSR
leave it obd2 just buy a jumper for your ecu if you plan on upgrading your ecu.. also did you check your fuses to make sure none were burnt?
Old Jan 24, 2009 | 10:03 AM
oramac_eg's Avatar
all the fuses are good they just aren't getting any power
Old Jan 24, 2009 | 10:04 AM
mouab18c1's Avatar
i dont see how going obd1 will make your windows,etc working
Old Jan 26, 2009 | 12:29 AM
oramac_eg's Avatar
when it was stolen they cut wires im assuming it had an alarm and they meesed them all up
Old Jan 27, 2009 | 04:52 PM
Hippslsvtec18's Avatar
sounds like your relays are bad for your windows, or a bad fuse or two somewhere, changing the ecu wont help the situation... im going to be switching to a p28 obd-1 ecu in a week or so, but thats because im adding more stuff to my teg and i want to be able to tune it, check your fuses and relays
luvmihatch
May 28, 2012 09:22 AM
RidingMark
Nov 22, 2006 02:42 AM
dapump2003
Texas -OK -LA (Sales)
Jul 26, 2006 01:57 PM
kennyvb
Aug 25, 2004 02:19 PM
