Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Front End Squeaks!
Old Jan 24, 2009 | 07:17 AM
John Haggerty's Avatar
Default Front End Squeaks!
First post here.
I have an 2006 Civic LX coupe stock. 75,000 miles. The front end squeaks alot. I suspect some of the noise is where the coil springs make contact to their seat.
What can I do to quiet the front end. Not looking to do much more than lubricate something. What all can be lubricated up front?
Thanks
Old Jan 24, 2009 | 04:05 PM
DA_Jay9's Avatar
Default Re: Front End Squeaks!
try lubricating the shock piston, i also had the same problem when i had my 07' but
i was running lowering springs.
Old Jan 24, 2009 | 04:11 PM
ironworker's Avatar
get a grease gun and hit all the grease cerks in the front end. might help
Old Jan 25, 2009 | 02:20 AM
I don't any grease fittings anywhere. Nothing that was meant to be greased.
Old Jan 25, 2009 | 03:27 AM
EnjoyTheRideDC2's Avatar
I'd like to know how one goes about lubricating a shock piston outside of the shock assembly itself.......
Even if you meant to say Shock Rod, still I would like to know how you lubed it and how did the lube kill the squeaking?
To the OP, I say just lube all your rubber suspension bushings since they squeak when they are dry, worn, or installed incorrectly.
Old Jan 25, 2009 | 06:34 AM
spoonfedcrx's Avatar
You people are idiots.
Is the noise happening when you're going over bumps? Dpes it happen if you are parked and turn the wheel back and forth?
Old Jan 25, 2009 | 07:04 AM
Seems all bump related. Nothing to do with turning.
How does one lubricate bushings?
Old Jan 25, 2009 | 08:57 AM
ironworker's Avatar
And your not? douche bag
Old Jan 25, 2009 | 09:12 AM
FijiBlueFG2's Avatar
Road House
dutch bag?
Old Jan 25, 2009 | 09:20 AM
katzenjammer84's Avatar
Most likely a bushing.
Old Jan 25, 2009 | 09:55 AM
Silicone Spray and spray each end of the bushing, if they are OEM which I assume.
Old Jan 25, 2009 | 04:55 PM
Are you saying this does not make you an idiot? Have you ever even worked on your car? He drives a civic not a blazer.
I'm not being a douchebag cause all you are doing is wasting the op time. And for the guy who said lubricate the shock piston. It's a strut and that idea is just idiotic hence he is also an idiot.
To the original poster. Without hearing the noise in person I would suggest like mentioned before to lube the bushings. If problem still persists get someone to bounce the car up and down while you listen and try to pinpoint the noise.
Old Jan 25, 2009 | 07:35 PM
COCA GROUND ASSAULT NY's Avatar
75000 miles ,sounds to me like no greasing is gonna do the job, save the time and just replace ur struts and check ur springs if theyre in bad shape just replace them as well , its got 75k thats alot, .... Time for replacements
Old Jan 25, 2009 | 07:38 PM
Struts? Yes, 75K I can see struts having a warrant for replacement, but not springs. Quality springs will last a lifetime.
Old Jan 25, 2009 | 07:48 PM
Originally Posted by katzenjammer84
struts? Yes, 75k i can see struts having a warrant for replacement, but not springs. Quality springs will last a lifetime.
right thats why i said to check springs as well but i think its all stock what hes talkin about.. I know struts are probably shot though
Old Jan 26, 2009 | 06:04 AM
LOL HAHhAHahhAHaHa.I'm sorry, I'm going to have to side with spoonfed. He does have a point.
Old Jan 27, 2009 | 07:57 AM
75,000 seems early to change shocks. Lubing the bushings didn't do it. I'm probably going to wait until spring and consider changing the shocks.
Old Jan 31, 2009 | 09:12 PM
FA5Clown's Avatar
My 07 Civic Si has a sqweak on the right front tire when i pull into my drive way and go over speed bumps. only 10,000 miles on it. I didnt notice it doing it in the summer, could cold temp make the sqweak sound happen?
wdissident
Nov 6, 2008 09:48 PM
PasswordEM2
Honda Civic (2001 - 2005)
Nov 4, 2007 08:56 PM
tomato_man
Apr 17, 2007 11:03 PM
