Da overheating after replaced with a fluidyne rad.....
well i woke up to see all my coolant on the floor....i got a fluidyne rad......it still heats up like crazy after a couple min of warming and the engine and rad are hott as heLl.....what could it be????? please help
This may sound stupid but did you install a fan when you replaced your radiator? Check to be sure your thermostat isn't messed up, also, did you get pre-mixed antifreeze? The un-mixed you have to do a 50/50 mix with water or it will over heat.
