Lowering Help
Usually with that small of a drop, it is ok to use the stock shocks, but much lower than that, you might risk blowing them out, and even with those springs, and stock shocks, you might get a little bouncy, but nothing too noticalbe.
im rocking the sportlines and i love them. the ride quality is very good. it rides smoother than the oem springs on some situations, and sometimes its a little bit stiffer, but not anything bad. overall the ride is excellent. heres a pic of my car on sportlines.
does it look like stock camber?? lol about those s techs, ppl say those are bouncy. and they have the same drop as the sportlines but the rear on the s techs is .1 inch higher than the sportlines
Hey did this void your warrant? I'm running on stock everything, if I get the sportlines only is that okay? Thanks. Hows the ride quality?
if you goto jhpusa.com you can get the skunk 2 springs and shocks as a kit for like 500 and the camber kits like another 200 250ish. if i was you id buy shocks too. i had some blow out on my accord and it sucks driving a car with blown out shocks. if you want a good ride quality get new shocks and get the camber kit bc if you dont your gonna have to buy tires in a month which is gonna be more than the camber kit anyways
Wait are those your stock tires? What if there are alot of people in the car will it affect the ride?
I went to the website but are you talking about just buying two items? or Is it reallu a kit for 500?
Ahh yes, just the right person. I was looking into getting skunk2 shocks and springs. But I've also came across HFP. Which do you prefer? Is the HFP Drop significant?
The HFP set-up is great and an improvement over the stock struts and Tein S springs.
The drop is about 3/4 of an inch. I just had a re-alignment and will not have to deal
with the rear camber issue. The car drives great and I don't have to worry about
speed bumps, big dips etc. The only thing I miss with the Tein S springs is the look
with the larger drop.
im going to answer all of your questions. going from your first post to your most recent.
1.) well the spring retailed for 335, and i got them for 225. the rear camber kit from skunk2 was 328 and i got it for 230. and i got them installed for 100 bucks.
2.) i have no clue if it voided my warranty. and the ide quality is similar to stock.
3.) those are not my stock tires. those are falken ziex's and the size is 225/45 r17. my car rides smoother with more people in it.
K5:
1.)yes those are 225 =] one downfall on the 225's though.
they are slightly wider than my oem mudflaps so water just flings up the side of my car
K5:
A good wax will keep it safe. Low offset with matching sized tires would look sick especially with your drop. Gotta make some sacrifices right?
oh i know that. but im just saying, like after you wash your car and you drive it sometimes water will fling up. and it comes up behind my rear tires cuz my mudflaps cant stop it. i just get a moist towel and wipe it off and its good to go
