need help please, ls swap into 91si hb
Old Jan 23, 2009 | 07:03 PM
ximportman's Avatar
Default need help please, ls swap into 91si hb
hey everyone, im going to be doing a ls swap into my 91si hb, and am looking for a how-to write up/directions for the swap installation and any wiring mods, and a parts list for the things i will need besides the motor its self. like what axels, and other parts i will need, and also what year ls is the most simple to swap into my hatchy..
thanks all for any help
Old Jan 23, 2009 | 07:47 PM
mattlsef's Avatar
Default Re: need help please, ls swap into 91si hb
ok i cannot tell you everything about as mine does not work right and need help with that still i can tell you that you will need to modify or purchase a shift linkage get motor mounts from somewhere like hasport or arizona race machine a wiring harness from them as well it comes with a short directions paper on what to do with the ecu pins you will need the ecu from the donor motor also on the passengerside i belive under the hood of the teg there is a small box near front wheel well all of this can be researched online i found a book all about physicly doin the swap the front axles hubs discs and calipers can all pop onto the stock ball joints of the hATCH
Old Jan 24, 2009 | 08:58 PM
ximportman's Avatar
ok people im getting a rebuilt ls, out of a 95 teg, complete motor and tranny, and axles, and linkage and short shifter, and i already got a ls ecu in the car
what i need is directions on how to re-wire the distributor, and what ever else that needs to be re-wired and if the stock axle that goes with the motor will work with the motor in my hatch?
Old Jan 24, 2009 | 09:39 PM
D16SiHatch's Avatar
if you want to keep the engine obd1 you're going to need a ecu jumper harness, and with that you'll get the dizzy conversion harness as well.
http://rywire.com/store/8891-crxcivi...865868318f70ec
linkage won't work in your chassis unless you shorten it. you can use both of your axles i believe, so long as you are using the 95 intermediate shaft. if you have a da intermediate shaft then your driver side will have to be from a 90-93. passenger side though can be from anything. auto trans, manual trans, abs, non-abs, doesn't matter.
jdmej1dtspanda
Apr 22, 2014 05:04 PM
92d15b7
Sep 9, 2010 04:51 AM
latinracerct
Oct 10, 2006 11:25 AM
Teckademic
Sep 22, 2003 05:52 PM
vtecsiqt
Aug 24, 2002 10:08 AM
