rear t bracket on b18 swap
Old Jan 23, 2009 | 05:30 PM
ryanevansoh's Avatar
Default rear t bracket on b18 swap
hey guys im swapping a b18 into my 90 hatch and i have a question. do i need to put the rear t bracket from the integra on before i drop in the motor? becuase i dropped in the motor with the 2 sides mounts loosely bolted on and i cant seem to get the t bracket in there. thanks
Old Jan 23, 2009 | 06:00 PM
h224thgensedan's Avatar
Default Re: rear t bracket on b18 swap
On all of them that i have done i had the bracked allready on.
Old Jan 23, 2009 | 07:59 PM
Deetz's Avatar
Crazy Honda Guy
Use any 90-93 Integra rear t bracket and things will be good. I always have the braket on prior to dropping the engine in.
Old Jan 23, 2009 | 08:15 PM
ef9luie's Avatar
Everytime I do swap's i put the rear t brecket after, on ef's is a little harder because off the space but just keep on trying evently you get it.
Old Jan 24, 2009 | 12:46 AM
D16SiHatch's Avatar
yea its a pain in the dick to get on the rear bracket. i tried with the bracket installed in the chassis, droppin the engine into place. no go. then i tried bolting it to block and then dropping the engine in. didn't work either, just not enough clearance no matter how you swing the engine. i had to have the engine partially dropped into the car and then slide the bracket into place while lowering the engine down into place.
Old Jan 24, 2009 | 01:18 AM
I have the rear bracket on when i drop my h2b and thats a lot bigger than a ls
Canon Chhoun
Oct 27, 2018 01:06 PM
Akai Star
Mar 29, 2010 07:16 PM
curioso
Nov 22, 2009 02:50 PM
egtype-r
Mar 5, 2005 05:43 PM
gocivicgo
Aug 16, 2003 07:19 AM
