after mpfi swap its it pretty fast?
Old Jan 23, 2009 | 03:32 PM
builtsinglecam's Avatar
Default after mpfi swap its it pretty fast?
i have a d15b7 dx motor from a 92 civic in my ef with an si tranny now i have a mpfi swap almost done now i just want to know if it is fast is an si or slower? any inputs will be great
Old Jan 23, 2009 | 03:51 PM
ryanevansoh's Avatar
Default Re: after mpfi swap its it pretty fast?
i would bet pretty similar
Old Jan 23, 2009 | 03:58 PM
crazyassbill's Avatar
From: parkersburg,wv / belpre,ohio, wv or oh, united states
i have the same setup, i'm using the si intake, distributor and ecu.
its pretty peppy and will hit the limiter easily
4drEF's Avatar
Keyboard Humorist
You can look for a compression calculator to figure it out for sure, but as ryanevansoh said it's probably very similar.
Old Jan 23, 2009 | 06:02 PM
apekd's Avatar
well depending on the set up it can be slower, fast as or faster than the si. most setups i have seen deal with a newer intake mani, bigger TB and they seem to be faster than that of an si
brotherton16
Dec 15, 2002 06:52 PM
allmotorEG-SI
10
Mar 31, 2002 10:13 PM
iceman_pl
May 6, 2001 05:06 PM
