wooohoooo....Type R 22mm swaybar installed last night
Old Aug 7, 2002 | 06:38 AM
TurbothisLS's Avatar
Default wooohoooo....Type R 22mm swaybar installed last night
Well, I finally got the rest of my bolts yesterday.
I stayed late at Acura and put in the swaybar. The ride is completely different! Turns are more exciting and everything feels tighter and more sensitive. HIGHLY recommend this mod.
Anyone ever heard of the crossmember frame actually cracking due to the increased tension? I bought the BSQ kit, is that supposed to prevent that? I torqued everything with a torque wrench and followed the instructions on bsq's website.
Old Aug 7, 2002 | 06:41 AM
StockTeg's Avatar
Default Re: wooohoooo....Type R 22mm swaybar installed last night (TurbothisLS)
Cool . I plan to get a Type R sway bar soon too.
Old Aug 7, 2002 | 06:44 AM
Default Re: wooohoooo....Type R 22mm swaybar installed last night (StockTeg)
anyone know about the crossmember frame cracking at the bushing mount?
Old Aug 7, 2002 | 06:46 AM
bullz's Avatar
How much did you spend on the entire mod?
Old Aug 7, 2002 | 06:49 AM
backlash's Avatar
Default Re: wooohoooo....Type R 22mm swaybar installed last night (iLLestjr)
when I did mine 2 years ago it cost me about $100, including the BSQ kit.
Old Aug 7, 2002 | 06:51 AM
Default Re: wooohoooo....Type R 22mm swaybar installed last night (backlash)
i work for acura so i got it from them.
It ended up costing me about $90
Old Aug 7, 2002 | 07:02 AM
Doctor CorteZ's Avatar
did you reinforce the subframe ?
I really hope so.......
Old Aug 7, 2002 | 08:01 AM
BSQ's Avatar
BSQ
The cause of subframe tearout is when the larger
swaybar is mounted AWAY from the subframe. When the
swaybar is mounted in this fashion, the swaybar is
able to exert torque on the subframe and this stresses
(ie. flexing back and forth) the mounting points and
eventually causes the mounting points to pull away
from the subframe.
As with anything, an increased amount of leverage
makes it easier to do work. This is governed by the
lever law: force x distance = torque. As distance--or
the length of the lever--increases, the resulting
amount of torque also increases. (This is why it was
easier to move your big brother on the teeter-totter
when he moved towards the middle and you stayed out on
the end. You enjoyed increased leverage at the end,
while he suffered from reduced leverage near the
middle.)
The proper way to mount a large swaybar is to mount it
DIRECTLY to the subframe (eg. Integra Type-R). This
prevents the torque and stress on the subframe.
My Type-R rear swaybar mounting/reinforcement kit (aka. BSQ kit) does prevent subframe tearout, since it allows the Type-R rear swaybar to be mounted DIRECTLY to the subframe. The mounting/reinforcement plates also reinforce the subframe sheetmetal.
I have been running the Type-R rear swaybar (with my mounting kit ) for nearly 4.5 years with no problems. I have also been selling my mounting kit for over 2.5 years and there has been no reported problems.
Old Aug 7, 2002 | 10:07 AM
lshobo's Avatar
Default Re: wooohoooo....Type R 22mm swaybar installed last night (BSQ)
f*ckin excellent turbothisLS, i felt the same way when i got my r swaybar installed
now, onto the Benen tie bar
Old Aug 7, 2002 | 10:09 AM
Scary1109's Avatar
Default Re: wooohoooo....Type R 22mm swaybar installed last night (lshobo)
dam, now i can't wait for friday, that's gonna be great
Old Aug 7, 2002 | 10:12 AM
Tweakmeister's Avatar
Default Re: wooohoooo....Type R 22mm swaybar installed last night (Scary1109)
ahh where can i get one?
my order with ahmotor is still backordered.
Old Aug 7, 2002 | 10:14 AM
FD3S's Avatar
Default Re: wooohoooo....Type R 22mm swaybar installed last night (Tweakmeister)
BSQ - man do you just have everything written down somewhere and do cut and paste jobs? This subject comes up soo often
[Modified by FD3S, 11:30 AM 8/7/2002]
Old Aug 7, 2002 | 10:20 AM
csufweed's Avatar
the type R is 22mm? so is the Mugen... so is the mugen one just lighter or what?!?!
Old Aug 7, 2002 | 10:28 AM
BSQ's Avatar
BSQ
Default Re: wooohoooo....Type R 22mm swaybar installed last night (FD3S)
BSQ - man do you just have everything written down somewhere and do cut and paste jobs? This subject comes us soo often
You guessed it. No sense in typing the same thing over and over.
Old Aug 7, 2002 | 10:37 AM
BSQ's Avatar
BSQ
Default Re: wooohoooo....Type R 22mm swaybar installed last night (csufweed)
The only thing that will be lighter with the Mugen is your wallet .
Old Aug 7, 2002 | 12:25 PM
WOTTEG's Avatar
Excellent Post!
Excellent Point!
As if we need any weight reduction in the BACK of our cars . . . .
Old Aug 7, 2002 | 12:34 PM
ahead's Avatar
hhaha
Old Aug 7, 2002 | 01:28 PM
Isaac's Avatar
New User
Default Re: wooohoooo....Type R 22mm swaybar installed last night (ahead)
Congrats! It's easily the best mod for the money whether it's power/handling.
Old Aug 7, 2002 | 02:58 PM
ALF's Avatar
ALF
Same here. How long has it been since you ordered? I've been waiting since June.
Old Aug 7, 2002 | 04:08 PM
TKBLAZER's Avatar
Default Re: wooohoooo....Type R 22mm swaybar installed last night (ALF)
i installed my bar a few months ago and it is without a doubt the best mod you can do to your car....
BSQ gets a for his help with his mounting kit and instructions on install
Old Aug 7, 2002 | 09:40 PM
badnan's Avatar
Default Re: wooohoooo....Type R 22mm swaybar installed last night (TKBLAZER)
where did you get your rear sway bar at? ive been backorderd for a month and a half now. i want my bar damnit!
Old Aug 7, 2002 | 09:53 PM
shadowdawn's Avatar
Default Re: wooohoooo....Type R 22mm swaybar installed last night (badnan)
yea swaybar is the ONLY suspension mod my car has, and its the best bang for the buck ever :D I've had it on almost a year now and it holds strong, bsq mounting kit is second to none, the man knows what he's talking about
Old Aug 7, 2002 | 10:17 PM
jpaik's Avatar
Default Re: wooohoooo....Type R 22mm swaybar installed last night (shadowdawn)
yup, it's definitely been the best mod for me. even the $700 i spent on koni yellows and eibach sportlines can't compare.
Old Aug 7, 2002 | 10:44 PM
Brandon Chun's Avatar
Default Re: wooohoooo....Type R 22mm swaybar installed last night (jpaik)
I've had my Type R rear sway bar on for going on 3 years now, no problems whatsoever. Best suspension mod I did period. Best thing is I got everything for around 100 bucks including BSQ's mounting kit. Thanks BSQ
Old Aug 8, 2002 | 07:05 AM
Default Re: wooohoooo....Type R 22mm swaybar installed last night (Brandon Chun)
guess i have nothing to worry about!
thanks
