Engine Harness OBD1 B17A1 In 93 SI HB
Old Jan 23, 2009 | 02:21 PM
92GSRHB's Avatar
Default Engine Harness OBD1 B17A1 In 93 SI HB
Which engine harness would be the cleanest and easiest to install with the B17a in a 1993 Civic Si Hatchback??? I have the 1992 GSR engine harness for the B17... but I dont think the wires are the right length for the EG chassis??? Thanks
Old Jan 23, 2009 | 02:30 PM
autox228's Avatar
Default Re: Engine Harness OBD1 B17A1 In 93 SI HB
Does your car still have its original motor? If so, just use the that harness since it wired for vtec.
Old Jan 23, 2009 | 03:10 PM
92GSRHB's Avatar
yeah I still have my original D16z6 in now... So just use my Si's original harness? Everything plugs in to the B17? I dont want to cut anything on my Si's harness or my GSR's harness.
Old Jan 24, 2009 | 09:32 PM
92GSRHB's Avatar
Old Jan 25, 2009 | 02:29 AM
94EG8's Avatar
Seagull Management
The Si harness will work fine, but you will need to add the knock sensor wiring and cut and lengthen certain wires (you need to extend the IAT wiring for example) You could also use a '94 - '95 GS-R harnes which will just plug in and work.
Old Jan 25, 2009 | 02:51 AM
RunninEg6's Avatar
im doing the exact same swap except my hatch is a dx w/ no vtec. my b17 didnt come with a wiring harness so im using the one off my d15 and just adding vtec
Old Jan 25, 2009 | 06:30 PM
92GSRHB's Avatar
Alright cool... Ill prolly just end up getting a 94-95 teggy harness. Thanks guys
Old Jan 30, 2009 | 12:56 AM
RunninEg6's Avatar
here this should help too:
http://www.ff-squad.com/tech/wiring/...ktowerplug.jpg
http://www.ff-squad.com/tech/wiring/wiring.92-95.jpg
Old Jan 30, 2009 | 05:39 AM
b16vt3c's Avatar
i hate b17 i rather go wiff a jdm b16a or jdm b18c
cus the shyt is on my cusins b17 the long block is most of the time ***'d up
dats y i go wiff a b16a or b18c jdm motors intead of usdm motors
Old Jan 31, 2009 | 05:09 PM
RunninEg6's Avatar
i would too but for $900 it was a deal i just couldn't pass up. plus it was rebuilt w/all type r internals from the block to the head
Dorkenheimer
Apr 4, 2016 09:51 AM
EF7
Sep 25, 2006 09:06 AM
Totall Insane
Jul 6, 2006 06:47 PM
bbrian
Oct 22, 2005 11:18 PM
Crimson_Tide
Jun 30, 2005 12:23 PM
