Suspension & Brakes Theory, alignment, spring rates....
Bleeder valve snapped in half..
Old Jan 23, 2009 | 12:53 PM
eiriksmil's Avatar
Default Bleeder valve snapped in half..
The bleeder valve broke off as I was bleeding the brakes. It's hollow. Would it be a really, really, really dumb idea to just screw some screw in the hollow part that's left? The threads on my screw is grabbing in the broken, hollow bleeder valve (or what's left of it).
It would just be a temp. solution for being able to drive on a frozen lake tomorrow (11 pm here, everything is closed), but it's about 220 miles of driving back and forth...
Old Jan 23, 2009 | 01:55 PM
kommon_sense's Avatar
Default Re: Bleeder valve snapped in half..
you can find a generic replacement bleeder screw at most autoparts stores. I wouldn't feel comfortable with a broken bleeder.
Old Jan 25, 2009 | 10:24 AM
94CivicSi's Avatar
You won't be able to bleed it if it's not hollow.
I had a hell of a time finding a replacement in any local parts stores the day I broke one. Ended up having to go a wrecking yard and pull a used one.
Jota
Engine Machining & Assembly
13
Apr 10, 2016 03:02 AM
black91
Nov 8, 2005 05:23 PM
Alex Goodman
Jan 29, 2005 11:45 AM
vulgar_si
Nov 18, 2004 05:31 AM
