mpfi then obdo ls swap
Old Jan 23, 2009 | 12:36 PM
builtsinglecam's Avatar
Default mpfi then obdo ls swap
i just want to know if after i do the mpfi swap then after that what other wiring or things ui need to do to throw in a obdo ls motor in?
Old Jan 23, 2009 | 12:42 PM
Singlecam4dr's Avatar
Default Re: mpfi then obdo ls swap
what kind of car?
Old Jan 23, 2009 | 12:54 PM
Originally Posted by Singlecam4dr
what kind of car?
90 dx hatch
Old Jan 23, 2009 | 01:51 PM
anyone?
Old Jan 23, 2009 | 01:53 PM
GroundZer0 336's Avatar
should just need the mounts and shift linkage. all the plugs in the car are already obd0 so im pretty sure it just plugs right in.
Old Jan 23, 2009 | 02:02 PM
nothing else ok thankx
Old Jan 24, 2009 | 01:02 PM
ya thats all other than ecu for the ls.
Old Jan 24, 2009 | 01:11 PM
BLU CIVIC's Avatar
Track Advocate
buy my obdo ls ecu
i know, shameless plug
Old Jan 24, 2009 | 03:17 PM
lilsicsoul's Avatar
Don't use the ls ecu...unless u plan on doing the E.G.R wires...
Best bet wit no check lights is.. A 90 si ecu ( pm6 )
Old Jan 24, 2009 | 04:04 PM
i used a pm6, thats the obd0 ls one right? i never had to deal with any egr wires, i didnt think they came with egrs??
Old Jan 24, 2009 | 05:14 PM
Clipsed's Avatar
what kind of car?
Originally Posted by builtsinglecam
90 dx hatch
You are incorrect, he has a DX which is MULTI POINT FUEL INJECTED. He has some wiring to do... See the link...
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
You sir are also wrong... You used the WRONG ECU in your swap. You used a PR4 AUTO ECU... Automatics came with EGR's while the 5 spd's didn't.
Old Jan 24, 2009 | 06:48 PM
[QUOTE=Clipsed;37142132]You are incorrect, he has a DX which is MULTI POINT FUEL INJECTED. He has some wiring to do... See the link.
no i already converted the wiring to mpfi but what i want to know is would an obd0 manual ecu work with the dx harnest? and all the da engine mounts line up in the ef chassis CORRECT?
Old Jan 24, 2009 | 07:21 PM
Clipsed's Avatar
no i already converted the wiring to mpfi but what i want to know is would an obd0 manual ecu work with the dx harnest? and all the da engine mounts line up in the ef chassis CORRECT?[/QUOTE]
If you already converted to MPFI then it is a matter of getting B series swap mounts into the EF chassis, getting a b swap into ef chassis shift linkage, and mounting it in. You will also need an OBD0 PR4 5 speed ECU. PM6 will work, but you will not have the power since it is a single cam ECU.
Old Jan 24, 2009 | 07:51 PM
If you already converted to MPFI then it is a matter of getting B series swap mounts into the EF chassis, getting a b swap into ef chassis shift linkage, and mounting it in. You will also need an OBD0 PR4 5 speed ECU. PM6 will work, but you will not have the power since it is a single cam ECU.[/QUOTE]
thank for the help!
Old Jan 24, 2009 | 07:56 PM
i do have a pr4 in mine. my bad haha.
ELSUICIDA
16
Nov 22, 2006 05:09 PM
4DRmafia
Apr 29, 2005 05:54 PM
89 pos
Mar 19, 2005 07:23 AM
LSVTEC96HB
May 4, 2003 09:45 AM
twitchm80
Oct 14, 2002 08:37 PM
