Can i use 95 civic charcoal canister?
so i jsut bought my little bro 95 civic.. i broke the charcoal canister tip that hooks up with a hose that goes to intake manifol on my 94 ls integra.. can i use the civic's charcoal canister? is ther any difference or i should be ok to pass smog..thx
thx for the advice..but can i use the civic charcoal canister on my integra to pass the california smog? civic 95 and integra 94 evap or charcoal canister are the same or no?
Probably not. I've had so many problems with the charcoal canister it's not even funny. 2000-2001 Integra are the same. 1998-1999 Integras are the same. 1994-1996 are the same and I don't remember which one the 1997 is compatible with. They do a new test at smog shops, I believe for 1996 and under, to see if the evap and charcoal canister is working and if it has any leaks. Do not use another model or year other than the one made for your car or it will not pass. Besides the brackets and hose diameters and sensors all vary and you'll have hell getting it to work. I think mac_24_seven has a used one off a wrecked Integra that'll work on your car. Hit him up or post a WTB. Double check compatibility too so you don't get the wrong one in case I'm incorrect.
JDMCivicEF9
Mar 8, 2003 12:56 PM
