obd1 to obd0 dizzy wire conversion (pt 2)
Old Jan 23, 2009 | 09:24 AM
lilsicsoul's Avatar
Default obd1 to obd0 dizzy wire conversion (pt 2)
Is ther a way to convert a obd1 dizzy to obd0?
Internals?
CuTing the plugs?
I know some 1 has to know how to do this..
I Don't want 2 convert my car to obd1..
Last edited by lilsicsoul; Jan 23, 2009 at 09:25 AM. Reason: I ment to PUt (( obd1 to obd0 ))
Old Jan 23, 2009 | 09:53 AM
h224thgensedan's Avatar
Default Re: obd1 to obd0 dizzy wire conversion (pt 2)
Why dont you want to convert to obd1.
Old Jan 23, 2009 | 09:56 AM
01-0041's Avatar
or look at the faq - the answer is YES!
Old Jan 23, 2009 | 10:37 AM
lilsicsoul's Avatar
Obd1 TO obd0..
I did check FAQ.s...
Old Jan 23, 2009 | 11:51 AM
alx_90ef's Avatar
i need help with this too=/
i dont wanna put and obd1 ecu i wanna keep my obd0 one
but i need to use a y8 dizzy
Old Jan 23, 2009 | 12:43 PM
lilsicsoul's Avatar
Help Us!! Pleasee
Old Jan 23, 2009 | 01:49 PM
jlicrx's Avatar
why do you need to use Y8 distributor? - OBD0 Si/HF distributor bolts right onto the Y8 head - if you have a Y8, you should convert to OBD1 in order to control the VTEC
Old Jan 23, 2009 | 02:04 PM
lilsicsoul's Avatar
What abouT a z6 motor//?
Old Jan 23, 2009 | 03:52 PM
4drEF's Avatar
Keyboard Humorist
You can't use an OBD1 or OBD2 distributor with an OBD0 ECU.
HF/Si/Ex distributor bolts up to the Y8 head no problem.
You have to do some creative hacking of the same distributor to fit it to other heads like the Z6.
yoffer
18
Dec 17, 2007 05:13 AM
richboi
11
Apr 17, 2006 04:36 PM
vegaskurt
May 14, 2005 10:17 PM
civictypenos
Aug 1, 2004 05:57 AM
ABK
May 6, 2004 07:48 AM
