Suspension & Brakes Theory, alignment, spring rates....
JDM 5 lug conversion 36mm axle size question.
Old Jan 22, 2009 | 11:30 PM
Turbo R's Avatar
Default JDM 5 lug conversion 36mm axle size question.
I am puttin a JDM 5 lug conversion on my 99 civic si.
My question is, will CRV axles bolt right in?
or will i need to get a 97-01 prelude axle and swap the joints?
Old Jan 23, 2009 | 02:30 PM
ls-low-n-slow's Avatar
Default Re: JDM 5 lug conversion 36mm axle size question.
when i instaled the 5 lug on my cuzins car i used all the parts off a 00 intrgra type r
Old Jan 23, 2009 | 03:14 PM
Turbo R's Avatar
not the answer i was looking for.
Old Jan 23, 2009 | 03:35 PM
Mashimaro's Avatar
i think your answer was somewhere in the ITR forum...if i remember, someone was saying that the first gen CRV axle works (but i can't remember if it was abs/non abs, manual/auto..)
*knock on wood* i'm currently using JDM ITR 36mm axles and they're still fine
Old Jan 26, 2009 | 09:31 AM
Bl6da9's Avatar
I use the same 36mm 5 lug on my car. When buying axel buy them for a 99-00 CR-V 5 speed. Also if your front bearing ever go bad you will be buying the front bearing for a 99-00 crv 5 speed.
TheBeardedMamba
14
Apr 7, 2017 02:07 PM
sikwitit
Suspension & Brakes
Dec 3, 2009 04:11 PM
legomytego
Suspension & Brakes
May 15, 2008 08:46 AM
Lookin4DC2
Suspension & Brakes
Feb 12, 2006 12:05 PM
hbkxtbone
Sep 7, 2004 06:17 PM
