alternator belt squealing like a pig. that means...
thanks rexman.
i just looked up the specs for the belt tension. they say to:
- apply a 22lb force on the belt and measure the deflection.
- you should measure on the topside of the belt in the middle of the crankshaft pulley and the alternator pulley.
-deflection should be 9mm-11mm (0.35"-0.43"). on a new belt is should be 7mm-9mm (0.25"-0.35").
T--Rex
Jul 14, 2004 04:44 PM
