seattbelt beeping sound?
Old Jan 22, 2009 | 08:49 PM
KILLAB17VTEC's Avatar
Genetically Gay
Default seattbelt beeping sound?
ok,can someone tell me how to eliminate beeping sound on 91 civic sedan?both seatbelts driver/pass sealtbelt latch-up no problem but i keep on gettin this beeping sound.i already check all fuse they all checkout good?any ideas? thanks
Old Jan 22, 2009 | 08:56 PM
jdmed3's Avatar
Default Re: seattbelt beeping sound?
do you have harneses? and you can take it to a shop and get your ecu erased for the seatbelt check
Old Jan 22, 2009 | 08:57 PM
miguey310's Avatar
under the seat there a cable unplug it and ur done
Old Jan 22, 2009 | 09:00 PM
Genetically Gay
i know this been cover many times,but i got no answers.i already try that unplug both plug under seat.it still beeps.any other ways?
Old Jan 22, 2009 | 09:02 PM
miguey310's Avatar
near the seat belt where it clicks there ill be a cable unplug it
Old Jan 22, 2009 | 09:04 PM
p10hlm's Avatar
Originally Posted by jdmed3
do you have harneses? And you can take it to a shop and get your ecu erased for the seatbelt check
wut
Old Jan 22, 2009 | 09:07 PM
Genetically Gay
its it on the driver side or pass?i'm not tryin to take to shop.they charge so i better figure it out myself.
Old Jan 22, 2009 | 09:09 PM
Genetically Gay
can u tell me where extactly locate..thanks dude
Old Jan 22, 2009 | 09:10 PM
jdmed3's Avatar
Originally Posted by p10hlm
wut
its like chipping your ecu they erase the seatbelt check that makes it beep in the first place like if you dont have them in the seatbelt light on your gauge flashes... did this for a friends ls boosted da and cost him 140 bucks to get it chipped and the o2 sensors and crank sensor erased
Old Jan 22, 2009 | 09:12 PM
miguey310's Avatar
both
Old Jan 22, 2009 | 09:13 PM
jdmed3's Avatar
ya its not hard and it helps that the mechanic smokes too
Old Jan 22, 2009 | 09:15 PM
miguey310's Avatar
where u chick the seat belt there gonna have to be a cable
Old Jan 22, 2009 | 09:19 PM
jdmed3's Avatar
its connected to the motor he has a 91 so its the auto seatbelts (gay) and the cable runs down to the ecu atleast in the 91 da which i assume its the same <-- owns 88
Old Jan 22, 2009 | 09:51 PM
Clipsed's Avatar
nonononono! To get rid of the beeping, there is a black cover on the floor behind where the shifter and the vents are, take the cover off of the plastic screw, and unplug the green harness... beeping gone.
Old Jan 22, 2009 | 09:54 PM
jdmed3's Avatar
that will get rid of the beeping but your seatbelt light will flash as a response i think
Old Jan 22, 2009 | 10:06 PM
Clipsed's Avatar
no sir, it gets rid of the light and the sound.
Old Jan 22, 2009 | 10:08 PM
Genetically Gay
by the way its an auto.do i have to remove the plastic cover on the shifter to get to it?do u mean the e-brake plastic cover?
Old Jan 22, 2009 | 10:23 PM
D16SiHatch's Avatar
i thought it was behind the center console, like underneath the radio area?
Old Jan 22, 2009 | 10:33 PM
Clipsed's Avatar
well that is what I meant, guess I worded it wrong.
Old Feb 12, 2009 | 12:45 AM
Genetically Gay
bump..i did check behind the ashtray area don't see the green wire?i pull the carpet to see where the beeping from,sound like its coming from the ecu..red lights flashing?still tryin to figureout..
DC-4Silver
Acura TL, RL & ZDX
Jul 1, 2011 12:50 PM
kingmonkey
Aug 15, 2006 01:50 PM
elevatethis
Dec 29, 2003 12:43 PM
Integra_Boi
Mar 13, 2002 08:21 PM
Comtechgsr2000s
Feb 12, 2002 07:33 PM
