b17a1 into eg
Old Jan 22, 2009 | 08:08 PM
freshvibes's Avatar
Default b17a1 into eg
So I just picked up a b17 today for cheap and I'm confused as to what I need to drop it in. Seeing as how it's out of a da I'm assuming I would need 94+ integra tranny/driver mounts, rear T bracket? Is the driver side mounting post the same on da's as dc? I did a bunch of searching and couldn't find a straight forward answer.
Old Jan 22, 2009 | 09:16 PM
iamthefollower's Avatar
Default Re: b17a1 into eg
you will need a tranny and mounts, and your rear L mount.. the mounting post should be the same.. but since it's a b17a1 you won't need a distributor or anything because it's an obd1 motor... you'll also need a 94 up half shaft and axles.. you can use any b series linkages except del sol b series linkages..
Old Jan 23, 2009 | 05:13 AM
WhiteBB2's Avatar
iamthefollower seems to know his stuff.
Old Jan 23, 2009 | 05:18 AM
Jimster480's Avatar
In addition to what he said u will need an ecu.
Old Jan 23, 2009 | 05:11 PM
if he is getting the motor maybe he can get the ecu with the Gsr, it should be a p61 and will plug right in for him...
Old Jan 23, 2009 | 06:12 PM
Jimster480's Avatar
p61? I thought itw as a P72?
Old Jan 23, 2009 | 07:15 PM
94EG8's Avatar
Seagull Management
P61 - Ultra rare USDM B17A1 '92 - '93 GS-R
P72 - USDM/JDM B18C/B18C1 GS-R/SiR-G
Old Jan 23, 2009 | 08:06 PM
padme's Avatar
wow.... a B17A1 huh??
where ya get one of those??
gotta be feeling really special....8)
Old Jan 23, 2009 | 08:14 PM
flipkc's Avatar
I got one in my EK, I love it!
Old Jan 24, 2009 | 07:58 PM
yeah the b17's are very nice.. I was wanting one, but here they wanted one for more than a b18c1.. I told them to forget it lol.. they are hard to come by motors though...
Yeah 94EG8 done answered the ? for me lol.. thank you...
Old Jan 25, 2009 | 05:43 AM
Jimster480's Avatar
ah so rare computer for rare motor, makes sense :X
Old Jan 25, 2009 | 09:31 AM
JaydmEg's Avatar
b17 sux... its just an uber rare motor other then thats its blahh..... dont mean to hate.. the only good thing is b17 head can use some parts off a b16 intake mani.. b18c1 cant.
Old Jan 25, 2009 | 12:46 PM
cvcdx's Avatar
speaking from experience behind the wheel of a b17a in an ef chassis,.. there is not too much difference between the b16 and b17 for torque but it's definitely a rare motor... the only reason i got it was cause it was readily available to me but that was a few years back... the p61 computer is awesome because of the knock sensor... its saved my *** a few times i've hit fuel cut off
Old Jan 25, 2009 | 01:29 PM
captivahach's Avatar
ive got a b17 in an eg and i use the shift link out the 92 integra and th axles also. but i did have to use the 94 rear mount. Also u may have to have injectors depends if the car had the resistor box from the factory
Old Jan 25, 2009 | 04:20 PM
to use the axles out of it in an Eg he would have to change the seal on the hydro tranny for the one that comes in the cable tranny so that the axles can fit...
burnoutboy
Aug 30, 2013 02:05 PM
418whpturboD
Jan 3, 2008 11:45 AM
civicb16eg
Northern California (Sales)
Aug 31, 2007 07:48 PM
crazyguy
Jun 11, 2007 11:38 AM
civickiller
Jan 24, 2006 11:22 PM
