built h series short block
i have been doing as much research as possible and can not come up with a decision, i am building a second dd/weekend car. and need a reliable short block built. i am only building this thing once and it needs to be done right. i have a few different companies in mind and need your help telling me who can build a bottom end that will hold up to anything i can throw at it, and remember it has to be reliable.
i have all the parts i just need to find a company to do the sleeving and assembly.
h22a closed deck block
je/endyne roller wave pistons
manley turbo tuff rods
oem oil pump
all oem gaskets
stock crank
arp main studs
balance shaft delete
a couple of companys i have in mind are, laskey racing, jg engine dynamics, and erl.
thanks for all your help, i would really like to hear from the guys that have used there engines and have person experience and reliability feedback.
please give your reasoning and possibly a price.
oem oil pump
all oem gaskets
stock crank
arp main studs
come on guys help me out. i would love to have erl build it cause to me it seems like you get the most work done to the motor to ensure longevity but i dont know if thats true and it is 2500 for them to build the short block if i supply all of the parts so all you get is sleeving and assembly. where laskey it is like 3000 but that is them supplying the pistons, rods, bearings, oil pump and balance shaft removal kit. would i be getting the same or BETTER quality by going with laskey?
