VTEC Solenoid Troubleshooting (Fixing the solenoid itself)
Old Jan 22, 2009 | 07:47 PM
Cyphear's Avatar
Default VTEC Solenoid Troubleshooting (Fixing the solenoid itself)
This took me forever to diagnose, but my VTEC solenoid is bad. My solenoid seems fine, but VTEC wont engage when I use it. I finally tried my friend's solenoid and VTEC works.
I'd like to fix it instead of buying a new one (although I can do that if needed). Does anyone know what could be causing my VTEC solenoid to be bad? By the way, I just have it hooked up to a switch to the battery for troubleshooting purposes. The solenoid does move when I apply voltage to it, and I bought a new screen and blew compressed air through all the holes.
It's DEFINITELY the VTEC solenoid. When I say VTEC solenoid, I mean the entire piece (not the actual magnetic solenoid). Any ideas? Thanks.
Old Jan 23, 2009 | 12:12 PM
Cyphear's Avatar
Default Re: VTEC Solenoid Troubleshooting (Fixing the solenoid itself)
bump. Thanks.
Old Jan 23, 2009 | 03:11 PM
HiProfile's Avatar
Icon4 Re: VTEC Solenoid Troubleshooting (Fixing the solenoid itself)
Solenoids are basicly just a electromagnet core around a moving steel rod, in this case its connected to a valve. Sometimes they can short out, and draw lots of energy but not have much power. They also loose power when they overheat, which can be the case if its shorting out internally. You'd have to test the electrical resistance of the coil (across the plug) and see if its much different from the working unit.
Honestly they aren't exactly servicable. Solenoids either work well, or not, and Honda doesn't sell individual parts for the vtec solenoid. You'd really have to test it with pressure on the inlet port to see if it really works.
Old Feb 27, 2009 | 07:59 PM
blackcherry's Avatar
how can you determine if it is in fact the solenoid or not? the other day my turbo gsr did not go into vtec at all. when that happened i added a half a quart (was slightly low) and fixed a possible vacuum leak and it worked. but tonight vtec did not work again. . . . any suggestions?
Old Feb 27, 2009 | 09:17 PM
locash's Avatar
One word, DATALOGGING.
Old Feb 28, 2009 | 04:35 AM
Pleiadi79's Avatar
oilpressure is ok?
Old Feb 28, 2009 | 05:51 AM
dart2.2's Avatar
if it doesnt work. go to a dealership that sold you a lemon and test drive a civic and swap the solenoid. let them deal with fixing the problem. or hit a junkyard and find one there. where do you live. i have a spare i could sell you for cheap.
Old Aug 2, 2009 | 09:27 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
lol /thread
Old Aug 3, 2009 | 10:14 AM
HiProfile's Avatar
Originally Posted by full Circling
lol /thread
lolx2, I'm pretty sure someone thought that 6 months ago before you resurected this thread.
/lockthread?
Old May 12, 2010 | 11:44 AM
lsvtechatchy's Avatar
vtec engages when oil pressure is prime. if oild is low vtec wont engage. also vtec engages around 178 degrees. hows your oil pressure and engine temp?
Old Aug 17, 2012 | 11:00 AM
misti3's Avatar
I have a 2003 accord and someone told me it was the vtec soleniod but I'm not sure it's throwing code #P2646,Can anyone help?
Old Feb 4, 2013 | 04:23 PM
K20first's Avatar
My 2002 Si doesn't get past 4k rpm and it cuts out and does a violent jerk. What can it be? I already checked the vtec solenoid and throttle body, but they seem to be fine.
Old Feb 4, 2013 | 04:44 PM
wantboost's Avatar
Who is Mr Robot?
So you bumped a 4 year old very dead thread as opposed to searching or starting a new one.... good job
Old Feb 4, 2013 | 06:37 PM
K20first's Avatar
I don't know how to make a new one.
Old Feb 4, 2013 | 06:43 PM
wantboost's Avatar
Who is Mr Robot?
Click new thread in the top left corner
Honestly no one will answer you because they'll see the date of the first post or they'll reply without reading to the bottom, either way you don't get help
I don't really work on k series motors so I can't help you.
Old Feb 4, 2013 | 11:03 PM
turbohatch96y7's Avatar
Check your vtak fluid. Seems like its low.
civic017
Honda Civic (2001 - 2005)
Jan 3, 2009 07:03 PM
Midori Green
May 7, 2008 07:10 PM
jerbear!
Jan 7, 2004 10:14 PM
