Engine building Questions
Old Jan 22, 2009 | 05:44 PM
hondaluver12's Avatar
Default Engine building Questions
I'm building up a D15b7.
Head: stage 3 exospeeds cam, supertech valve springs, si valves, port&polish.
Bottom end: APR head studs&rod bolts, acl bearings, MABY stock rods i don't know(ppl say that that stock D rods can be spun with no problem to 8,500rpms, then theres ppl that break them all the time) and p29 pistons.
another question is that will a stock crank do? im not wanting to hold my breath every time i get on it. I wanna feel comfortable going to 7,500rpms. I never hear of any one swaping out there cranks for something better...any suggestions would be appreciated. And yes i searched......
Old Jan 22, 2009 | 05:50 PM
D16SiHatch's Avatar
Default Re: Engine building ?
You do not want the stock rods in there if you plan on revving over stock redline. definitely go with something that is h-beam and/or forged. i was reading the other day if you widen the crank journals you can run b18a/b ls rods and that would also suffice. you have to have wrist pin bushings as well though to accomodate d-series pistons. kind of a pain in the dick compared to just getting aftermarket stronger d-series parts, but it is an option none the less.
ninja edit: here's the thread talking about using ls rods on the d-crank.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/ls-connecting-rods-d16-2420829/
Old Jan 22, 2009 | 06:02 PM
Default Re: Engine building Questions
thanks, but the thread that u gave me was for a D16...the cranks are diff.....
Old Jan 22, 2009 | 10:20 PM
D16SiHatch's Avatar
true. sorry i didn't catch that. i knew the stroke was different to cause the 0.1L increase but i didn't realize the rod/crank journal widths are different between the two. in which case just go with aftermarket stronger d15 compatible rods. or since the price of a d16 bottom end isn't exactly expensive, you could always pick one of them up.
Old Jan 23, 2009 | 06:28 PM
Do you know where too find any aftermarket rods for a d15? All the rods ive found was only for d16's.... and you think i would need to have the crank balanced?
Old Jan 23, 2009 | 08:04 PM
Bserieskllr's Avatar
they dont make them, crower use to but stopped because not much demand for them, the stock rods will be fine for what your doing, the motor prolly wont make power up to 8500 maybe 8k but still i wouldnt worry i would just change the rod bolts out for arp's or new honda ones. Im almost positive you cant use the p29's in a d15, i cant remember why off the top of my head its been awhile but ill have to look it up and get back to you. You may be better off using a d16 block, or you can stick the 1.5 and just mill the head a bunch to raise compression.
Old Jan 24, 2009 | 08:18 PM
Im using a d15 just to be diffrent, and yes p29 pistons will work with a d15.
Old Jan 26, 2009 | 10:01 AM
Exospeeds 'stage 3' cam has a Powerband of 3000- 8200 RPM. But im only going to be reving to 7,500rpms. Are staock rods with APR bolts strong enough for that?
Old Jan 26, 2009 | 04:22 PM
The arp's are worth the extra insurance there what only $60 and yes they can handle it much better then the possibly stretched stockers, The D15's actually rev better then the d16's because of the shorter stroke and better rod/stroke ratio, I think the p29's sit to low in a d15, Have you installed them yet? I'd like to see them in there but im almost positive there gonna sit to low in the bore, but lmk.
Old Jan 26, 2009 | 04:32 PM
They would sit below but im going to be using vx rods. they will bring it up to where it needs to be
Stevenpace
Jun 23, 2013 09:10 AM
Project_SOHC_EX
Dec 19, 2009 11:58 AM
DCRB
Sep 9, 2009 01:43 PM
95CivicDx51
Nov 20, 2008 11:30 AM
Power Rev Racing
Oct 23, 2004 12:48 PM
