obd1 injectors obd0 wire harness Q..
Old Jan 22, 2009 | 04:31 PM
lilsicsoul's Avatar
Default obd1 injectors obd0 wire harness Q..
I have a d16a (93 jdm single v ) the car still obd0 wit obd0 injectors..
I cam across obd1 wire harness wit obd1 injectors.. If I cut the obd0 plugs and put the obd1 plugs and injectors will the injectors work?
Old Jan 22, 2009 | 04:37 PM
redb16coupe's Avatar
Default Re: obd1 injectors obd0 wire harness Q..
you need to bypass the resistor box and have an obd1 to obd0 jumper with an obd1 computer if im not mistaken
Old Jan 22, 2009 | 04:43 PM
lilsicsoul's Avatar
I don't want to make it obd1 just wanna know if the injertors would work..
Old Jan 22, 2009 | 04:47 PM
D16SiHatch's Avatar
you don't need to convert to obd1 to use the obd1 saturated injectors. splice on the clips and drop in the obd1 injectors. then all you have to do is remove the resistor box. its the grey box with a green plug on the driverside back corner of the engine bay. remove the box and solder the 5 wires going to it into eachother. (4 red/black wires and 1 yellow/black wire)
Old Jan 22, 2009 | 09:31 PM
lilsicsoul's Avatar
Thanxx..!
Sleepy_Red_hatch
Mar 4, 2006 08:59 AM
SupraRXZ
Feb 3, 2006 02:15 PM
e jay one
Sep 10, 2005 09:15 AM
91lsteg
May 15, 2005 11:32 AM
