FS: erl block,pauter,crower head,sparco,aeromotive,rc,hks,quiafe,turbo PART OUT!!
The car is sold now so i no longer need any of this stuff.
-All of this stuff was bought to put down 600whp- some of it was used for 464 miles on the dyno while tuning-thats it! some of it is new, i will specify below if it is new
-I am open to offers, but please do not lowball me.
-The things listed below as 'will not seperate' will not be! dont ask!
-if you are interested in a specific thing and i dont have pics of it, just ask and they will be posted-
-Prices do not include shipping- +3.5% for paypal
*SOLD*BBK 70mm TB- all sensors; complete-*SOLD*
*SOLD*OBD1 alternator-very clean!-*SOLD*
*SOLD*B series axles- only 464 miles!-*SOLD*
*SOLD*B series half shaft-*SOLD*
*SOLD*Autometer carbon fiber boost gauge; 30psi readout-*SOLD*
*SOLD*Endyn catch can; has one braided line and EARLS fittings included-*SOLD*
*SOLD*Seibon carbon fiber duckbill-*SOLD*
*SOLD*EG black floormats;very hard to find & mint-*SOLD*
*SOLD*Fluidyne dual core half size radiator w/ oem fan-*SOLD*
*SOLD*STR b series bronze fuel rail-*SOLD*
*SOLD*Aeromotive A1000 fuel pressure regulator w/ marhsalls pressure gauge-*SOLD*
*SOLD*Aeromotive fuel filter-*SOLD*
*SOLD*All parts are connected via -6 braided line and Earl's -AN fittings;*SOLD*
*SOLD*RC 1000 peak and hold injectors w/ o rings for intake mani-*SOLD*
*SOLD*BNIB ERL MID sleeved 84mm B18C block- comes with new rod, main and thrust bearings-spec'd for the block already*SOLD*
*SOLD*-comes with oil pan, main seal, pickup, windage tray, and brand new Honda Oil Pump-still in bag!*SOLD*
*SOLD*-also comes with new matching B18C crank that was meant for the block and BNIB oil pump-*SOLD*
*Will not seperate anything from the head-94 GSR casting
-All machine work and part installation was done at Pure Tuning in Toledo, OH- including intake mani- http://www.pure-tuning.com/pages/services/honda.htm
-Spec C package, plus intake manifold porting on runners and by tb to accommodate the 70mm tb
-Crower Titanium springs and retainers
-KMS bronze valve guides
-Ferrea standard size valves
-OEM Honda seals and keepers
-01' ITR cams
-01' ITR LMA's
-Skunk2 cam gears
-STR silver cam seal
-comes complete with all sensors and vtec solenoid- $1,600
*SOLD*Golden Eagle LS headstuds-only torqued once-*SOLD*
HKS TypeII BOV- $250
*SOLD*Intercooler piping for eg with ramhorn manifold w/ PWR couplers and T bolt clamps- 3"hot side, 2.5" cold side-*SOLD*
*SOLD*31x11.5x3 intercooler; 3" end tanks-*SOLD*
*SOLD*JG Victor X intake manifold- ported runners and plenum; comes with all sensors, fittings, and misc hoses-*SOLD*
*SOLD**Will not seperate ignition stuff-*SOLD*
*SOLD*-OBD1 gsr dizzy setup to run external coil*SOLD*
*SOLD*-MSD Blaster 2 coil*SOLD*
*SOLD*-MSD dizzy cap with coil wire*SOLD*
*SOLD*-MSD 6A ignition module*SOLD*
92-95 civic Neuspeed front upper strut bar- $50
*SOLD*Pauter B18c1 connecting rods-inspected/mic'd by D&D in Cincinnati, OH-perfect condition-*SOLD*
*SOLD*Sparco Torino black on black driver and passenger buckets with sparco brackets- one small blemish on bottom front of passenger seat(see pic)-*SOLD*
*SOLD*Sparco Clubman 4pt Camlock harneses;blue in color-*SOLD*
*SOLD*B series shift linkage with shifter-*SOLD*
*SOLD*Spec stage 5 clutch; 575 torque capacity part number SA265- comes with brand new SPEC throwout bearing-*SOLD*
*SOLD*Tial 44mm wastegate; anodized black-*SOLD*
*SOLD*AIResearch t3/t04 turbo- dont know the specs, just picked it up to basemap/sort out problems on the motor before i put my good one on; no shaft play at all -*SOLD*
*SOLD*T3 Turbonetics 60-1; .70 AR compressor housing, .63 A/R turbine housing w/ 5 bolt discharge-*SOLD*
*SOLD*LS tranny w/ Quaife LSD- included with sale will be the lifetime warranty on the LSD-*SOLD*
*SOLD**Will not seperate OneFab turbo products-*SOLD*
*SOLD*-OneFab ramhorn manifold w/ 44mm wg flange*SOLD*
*SOLD*-OneFab 3" 5 bolt flange downpipe w/ flex pipe; has two threaded bungs for o2 and wideband*SOLD*
*SOLD*-OneFab dump tube w/ 44mm wg flange*SOLD*
Greddy black turbo timer- $50
*SOLD*Hondata GSR intake mani gasket-*SOLD*
Cometic 84mm VTEC Headgasket .030mm thickness- $40
*SOLD*OBD1 gsr complete engine harness-*SOLD*
-01' ITR cams
-01' ITR LMA's
-Skunk2 cam gears
