178.8 WHP ITR
Old Aug 7, 2002 | 12:03 AM
capcon83's Avatar
Default 178.8 WHP ITR
I have a ITR with Comptech 4-2-1 mig welded headers, apexi V-AFC controller, AEM CAI, Spoon camshafts, Spoon camgears.
i got my car tunned for 3hr and only pulled 177.8.
i was wondering is this right? or did the guy not tune it right?
i was there when he tunned it and he hardly touched the camgears, he messed wih it for a while then he messed with the V-AFC controller and thats were i made my power. But now my check engine light comes on and it says im too righ!
so i dont know what to do.
does anyone have an opinion on what should i do or what should i get like an exhuast because i dont have one, running on stock itr exhuast.
Old Aug 7, 2002 | 12:22 AM
zijiejijeijrkjk's Avatar
Default Re: 178.8 WHP ITR (capcon83)
Find a better tuner.
Old Aug 7, 2002 | 12:28 AM
R-1303's Avatar
Default Re: 178.8 WHP ITR (scott_k)
How did u spend on parts alone?!?!?
Old Aug 7, 2002 | 12:37 AM
capcon83's Avatar
a lot
i think i need to find a better tunner
Old Aug 7, 2002 | 12:52 AM
B00ST2nR's Avatar
what are the specs on Spoon cams? 178.8 is low for a car with aftermarket cams... Find a better Tuner.
Old Aug 7, 2002 | 03:42 AM
GoodFella's Avatar
Unfortunate Clevland Sports Fan
find another tuner, doesnt look like that guy knew what he was doing. i put down 174 whp on 17" racing harts with a vafc, comptech header, hi-flow cat, and exhaust. i just installed toda spec b cams and cam gears so i will have to see what im putting down now when i get it tuned.
Old Aug 7, 2002 | 03:56 AM
Cosworth's Avatar
Your peak WHP doesn't seem as high as some of other people's, but what about your midrange? When you compare the baseline dyno graph to the final dyno graph, do you see a huge different in the midrange power? 178WHP seems to me like camgear wasn't messed around at all... you should be able to put down that number with just I/H/C + cams + V-AFC.
If you need a new tuner, I say you talk to one of the Honda-Tech ITR/Tech forum members. There are several talented tuners on this board throughout the country who will help you out for a minimal cost (beer).
Old Aug 7, 2002 | 04:51 AM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
Default Re: 178.8 WHP ITR (Cosworth)
agreed... anyway you can post your dyno sheet- and maybe rattle off a few of the settings- someone here (with more talent than I) should be able to give you a better heads up on what may be wrong and how to correct it.
178 whp is still not bad, but it seems like it should be better
later
matt
Old Aug 7, 2002 | 06:02 AM
RTW DC2R's Avatar
Default Re: 178.8 WHP ITR (champITR)
well, all I can say is that I pulled 178whp with just USDM Mugen headers and AEM.
Old Aug 7, 2002 | 06:09 AM
S&P500ITR's Avatar
New User
what was your baseline dyno. that should tell you more than comparing your peak numbers with everyone elses.
Old Aug 7, 2002 | 06:38 AM
SergEK's Avatar
Default Re: 178.8 WHP ITR (S&P500ITR)
I think its the cams.
The Spoon cams from what I understand are only slighly more agressive than the R cams thus the slight power increase.
But still with those mods, I would find a different tuner and see if they can find a few more ponies for you.
Oh yeah........run open header for a pass or two..........if you see a HUGE increase that could be a sign the exhaust is holding you back. Your mid range should pick up a few ponies running open header.
As soon as I wire up my P73 I will dyno my C5 with an AEM/ DC / TRM + VFAC to see if my baseline is similar.........from what I have seen the newer R motors with the slightly more agressive stock cams baseline near 170/118-120 so with I/H/E I would hope for at least more than 10 hp.
Old Aug 7, 2002 | 07:28 AM
JohnnyBoy's Avatar
Default Re: 178.8 WHP ITR (SergEK)
I've seen an ITR with spoon cams, Comptech header....a few other mods pull 190WHP on the dyno.....You should be able to squeeze a little more even with the stock exhaust.
Old Aug 7, 2002 | 07:53 AM
R1525's Avatar
Default Re: 178.8 WHP ITR (JohnnyBoy)
I'm curious to know where you got your car tuned capcon.
Old Aug 7, 2002 | 07:57 AM
SamuraiJack's Avatar
Default Re: 178.8 WHP ITR (R1525)
where did you get it done at?
Old Aug 7, 2002 | 08:55 AM
MPH's Avatar
MPH
New User
Find someone who has a clue or do it yourself
Old Aug 7, 2002 | 09:06 AM
Cheap Bastard's Avatar
New User
Can't really compare numbers from different dyno's. What is your baseline, because what really matters is how much you gained with the tuning.
I always wonder why people don't get a baseline. It's a shame spending all that money to tune and not know how much you gained.
CB
Old Aug 7, 2002 | 09:10 AM
capcon83's Avatar
ill scan my dyno sheets and get them back to u. right know i have no scanner ill use my friends.
Old Aug 7, 2002 | 10:02 AM
capcon83's Avatar
Old Aug 7, 2002 | 10:04 AM
B2FiNiTY's Avatar
Looks smooth though...
Old Aug 7, 2002 | 10:06 AM
Rob :190:'s Avatar
Default Re: 178.8 WHP ITR (B2FiNiTY)
the Rockies looks smooth from 200 miles away...
anyway to blow that image up?
MPH's Avatar
MPH
New User
Maybe lower #'s because it's not a Dynojet?
Old Aug 7, 2002 | 11:16 AM
Looose_R's Avatar
Default Re: 178.8 WHP ITR (MPH)
get a fuel presure riser to adjsut most of your fule settings, then fine tune with the vafc. you cant jstu crank up a shitload of fuel with the apexi, thats where your code is coming from after about 12% increase its gonna throw
Old Aug 7, 2002 | 11:42 AM
mafay2's Avatar
New User
Default Re: 178.8 WHP ITR (b20bastard)
I was at +25% on my VAFC with no code. But I know that the VAFC is not that good at adding fuel, so I would say go get a FPR!!
Old Aug 7, 2002 | 10:43 PM
capcon83's Avatar
well i live in sac cali
i got my car tuned from motorsports dynamics he was on it for like 4 1/2 hours and only charged me for 3hr and that was a grip $360.00 couase $100 and hr and 60 for adding another hole to the cat to find out the air pressure
Old Aug 7, 2002 | 11:03 PM
Chris's Avatar
go to http://www.dynospotracing.com
Lawrence will get you there.
