Suspension & Brakes Theory, alignment, spring rates....
Is it possible to switch ground control springs front to back?
Old Jan 22, 2009 | 12:17 PM
JaySauce's Avatar
Default Is it possible to switch ground control springs front to back?
Thanks
Old Jan 22, 2009 | 01:21 PM
bopbop93030's Avatar
Default Re: Is it possible to switch ground control springs front to back?
if it is the same lenght, then yes.
Old Jan 22, 2009 | 01:25 PM
JaySauce's Avatar
How can you tell the difference between the front and the rears?
Old Jan 22, 2009 | 02:21 PM
Tyson's Avatar
you can do whatever you want.
read the springs by the numbers.
Old Jan 22, 2009 | 02:46 PM
The front is usually is shorter than the rear
Old Jan 22, 2009 | 05:18 PM
JaySauce's Avatar
So one person says yes and the other no....
What is it?
Old Jan 22, 2009 | 07:43 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Perhaps for your Accord, but most Civic/Integra GC's run shorter rear springs than front.
Sure you can swap them even if they're not the same length. But you could possibly have issues with one end not going low enough or high enough due to the different spring height.
Old Jan 23, 2009 | 08:26 PM
Targa250R's Avatar
be professional
What is it?
Yes they can be swapped.
Whether or not it is actually a good idea to swap them is another story. It depends on the free length and rate. You can determine these specs via the part number printed on the spring.
If you use springs that are inadequate for the application, you will run into problems.
Lim
Jun 8, 2009 04:00 PM
FinalJinx
Suspension & Brakes
Sep 29, 2008 12:32 PM
fishnfst
Sep 1, 2003 02:56 AM
mackymcg
Aug 1, 2002 11:07 AM
AssPenny
Jan 30, 2002 09:42 PM
