Cel Code 3
Old Aug 6, 2002 | 11:33 PM
Evil EG's Avatar
Default Cel Code 3
Installed the AEM Fuel Rail with the AEM FPR. Ever now and then I get a CEL CODE 3. I know what the code is, but what is causing it thx.
I think it has to do with my Fuel Pressure but not sure.
Old Aug 7, 2002 | 03:06 AM
kenji's Avatar
25 Year Member
Default Re: Cel Code 3 (BVM)
Code 3 is a MAP sensor code (you already knew that).
In your sig it states that you have a Drag turbo kit. You did not specify if you are running aftermarket engine management or check valves with OEM ECU.
As you already know, positive manifold pressure on a Honda/Acura with OEM engine management will cause a code 3 or code 5 (MAP sensor).
Give us more details so we can help you.
-kenji
Old Aug 7, 2002 | 07:28 AM
Evil EG's Avatar
Default Re: Cel Code 3 (kenji)
stock ecu with the V-AFC. No check valves.
Old Aug 7, 2002 | 08:59 AM
Kataku2K3's Avatar
Get those check valves in.. I would just with a Hondata 2b and GM 3 bar MAP... that should solve all your problems. Then you just gotta tune it.
DA_zooooms
Aug 10, 2009 09:08 PM
lscrxhf
Jul 4, 2006 08:08 AM
Nextelbuddy
10
Jun 19, 2005 07:24 AM
highboostb18c1
Mar 28, 2005 09:06 AM
TurboDC4
Mar 20, 2003 10:41 AM
