Accord heater knob cable broken.
Old Jan 22, 2009 | 10:59 AM
TwoKSiR's Avatar
Default Accord heater **** cable broken.
So I put it on hot manually under the hood. But it still blows cold. Is there a second thing under the dash that you have to manually move also? It's a 95 Accord EX.
Old Jan 22, 2009 | 11:44 AM
P_Adams's Avatar
Default Re: Accord heater **** cable broken.
Yes, there is a heater Temp Blend Door which is also attached to the cable which also operates Hot Water Control Valve.
This is how it works:
Temp command thru twist ****
pushes/pulls cable which connectes from the Heater Control Head to the Tempurature blend door lever
pushes/pulls cable which connectes from the Blend Door lever to the Hot Water Control valve.
usually the water valve freezes / corrodes and one or both cables bend / kink or sometimes break right off.
P
Old Jan 22, 2009 | 11:48 AM
TwoKSiR's Avatar
It has a kink in it. Thanks.
Old Jan 22, 2009 | 11:49 AM
TwoKSiR's Avatar
Which was do I have to move the lever under the dash?
asoRm
Sep 18, 2014 07:41 AM
mcwulf30
Aug 17, 2010 08:24 PM
Sorcerer
Nov 8, 2009 12:16 PM
khmertek
Jan 28, 2009 01:56 AM
garrybloom
May 28, 2002 05:43 AM
