Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Intermittent No Start 09 Civic EX
Old Jan 22, 2009 | 10:52 AM
RutRow's Avatar
Default Intermittent No Start 09 Civic EX
I purchased this new in December. Since then it has failed to start at least 8 times. Always the same symptom. Turn key to start and I hear the starter spinning, but it does not engage the flywheel. 2nd time I try it will always start. I have an appointment tomorrow, but I have a feeling they will say they can't do anything unless it is failing. It is very intermittent. Sounds like the solenoid needs replacement. Just wondering if anyone else has seen this problem.
Old Jan 22, 2009 | 11:11 AM
av911's Avatar
Default Re: Intermittent No Start 09 Civic EX
Before starting the car, put the key in the II(On) position. Give it about 30 seconds and then start your car. I've had my car for 3+ years now and never had any problems starting the car, and still using the same battery that came with the car.
Here's my routine:
Get in car, put key in II position. Plug in my SG2, adjust radio volume and/or temperature controls if necessary. Put seatbelt on and start the car.
Old Jan 22, 2009 | 11:59 AM
RutRow's Avatar
I tried that too. Same result. I should say I've owned 2 other Civics before this one and never had an issue. My friend has an 09 also, and experienced the same problem just one time.
Old Jan 22, 2009 | 10:52 PM
MogreSSSJ's Avatar
sounds like a lemon to me
Old Jan 23, 2009 | 04:00 AM
-RideEmHard-'s Avatar
Here's my routine:
lmao! i do that to
Get in car, put key in II position. plug in my P2, put on my seat belt, adjust temp...
i find slower cranks in winter vs. my older civic would start on a dime...
let us kno what happened?
Old Jan 23, 2009 | 02:01 PM
RutRow's Avatar
As I suspected, the dealer was unable to duplicate the problem, but they did have a suspicion the dealer installed KARR alarm system was to blame based on my description. They replaced the controller module under warranty. If I don't see any problem over the next 2 weeks, I guess I can assume it is fixed.
loayo
11
Mar 12, 2012 12:49 PM
nighttrain33
10
Feb 25, 2007 08:10 PM
lowblazin
Nov 25, 2003 10:00 AM
