Tires on different wheels. I might be dumb
Old Jan 22, 2009 | 09:35 AM
bigsnorlax's Avatar
Default Tires on different wheels. I might be dumb
I just bought all new michelin :D tires for my 96 accord. By looking stuff up on the web my current wheels are 15x5.5 . And i would like to spring for these 98 alloy wheels that are 15x6. My question is dumb but with my tires could they fit an a rim thats half an inch wider? or would this require all new tires?
Old Jan 22, 2009 | 09:46 AM
P_Adams's Avatar
Default Re: Tires on different wheels. I might be dumb
All things being equal, if your new Michelin rubbers are either 205/60-65 you can go ahead and make the change. If they are 195's, you can still do it - but it may look a little 'wierd' what with the sidewall being wider than the tread. Either way, it may make a 1/4" difference on the overall width of the tire (at the sidewall), but won't cause a problem.
Old Jan 22, 2009 | 09:57 AM
bigsnorlax's Avatar
ill hafta go home n check the tires to see what i got exactly, but thank you for the info
Old Jan 23, 2009 | 06:37 AM
02 accord's Avatar
I ran sizes 205/60, 195/65, and 195/60 on both the 5.5 and 6 inch wide rims and it looked fine either way. There's barely any noticeable difference between the two rim widths.
Old Jan 23, 2009 | 06:53 AM
GoLowDrew's Avatar
Old Member
25 Year Member
X2.
I've done similar with 15" wheels for Civic. 0.5 difference in width on the same tire. The only downside for this was that I had to pay for new valvestems, mounting , etc, etc.
Old Jan 23, 2009 | 05:34 PM
dennis's Avatar
Was runnin 205/55's on the stock ex alloys back when I had my boosted accord. Wanted a lil more meat all around.
Old Jan 24, 2009 | 02:53 AM
johnlear's Avatar
Banned
Nearly all the tyre manufacturers seem to specify 6" as the ideal rim width for a 195 tyre, with 5.5" being the minimum permissable. 7" is usually the maximum permissable rim width for a 195.
When the manufacturer says "ideal" (or words to that effect) they mean their suggested best compromise between comfort and steering / handling response of the tyre, because the tyre gives a softer ride on a narrower rim, but is more responsive (but stiffer riding) on a wider rim.
Fitting a tyre to rims that are wider than the tyre manufactureres recommended max rim width is dangerous. Fitting to a rim under the min rim width may cause poor steering / handling because the sidewalls lose stability the narrower the rim is (and it may be dangerous in more extreme cases). A 205 tyre is too wide for a 5.5" wheel rim.
GloomyX
Apr 30, 2007 12:56 PM
spoonman362
Jan 3, 2007 03:27 PM
jdeli
Honda Fit
Apr 30, 2006 10:18 PM
boostincoupe
Feb 8, 2006 10:57 AM
