95 honda accord
You won't hurt anything.
After you've got it loose, then you can raise it up again to gain access to everything.
P
What are you using to break it loose? A breaker bar and the car on the ground, with wheel and tire on it, should do it.
Did you bend the side of the spindle nut out of the notch in the end of the shaft? It's the spot on the side of the spindle nut that is punched into the notch in the axle shaft. It keeps the nut from spinning off.
Andrea Deth
Jan 16, 2016 10:45 AM
chad olson
Jan 13, 2009 09:30 AM
