a/c and power steering in my car with my new swap
i have a 2000 honda civic dx with p/s and a/c and im about to drop in a 1994 acura integra gsr in my car and i was wondering could i use the 2000 honda civic si a/c compressor and use my oringinal ac line and and ac condensor and fan. as for the p/s same thing take the p/s from the 2000 honda civic si p/s pump and p/s line.... the question is will it work or wont work will it fitt or wont fitt please help want to do my swap the right way thanks in advance sorry about my grammar
:thum bup:
:thum bup:
I am not 100% sure but I thought the power steering pump work if you have B series brackets for it. I am not sure on the AC compressor.
you will need the power steering pump off of the integra. The B series and D series power steering pumps will not interchange. However the lines to interchange.
as for the a/c compressor. Your D series compressor will work but you need to go to honda and get an a/c bracket off of a 99-00 SI civic or find one used.
as long as your using your OEM header your stock fan/condenser should work fine if memory serves me correctly. If not you can solve it with a slim radiator fan but like said i think it will be fine
Just drop a B16a2 on my EG, as far as the P/S is concern you would need the P30 Brackets (top and bottom), P/S pump, and P/S high pressure hose off a DC2 Integra. You will have to bend the hose to fit.
I'm currently using Side engine mount (a/c bracket) off a 2000 SI
hope this will help
hope this will help
hope this will help
hope this will help
for power steering go here https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-retaining-power-steering-ek-b-series-swap-1822781/ that's what i used to figure out which pump i needed and what brackets. All the info is right there. The FAQ section of this forum will pretty much answer all of your questions. Just look for the sticky at the top of the page.
Oh and btw you need the a/c bracket from a 93-97 del sol not Si for the a/c swap using your stock compressor and the rest of it. Also you need an Si p/s pump and a GSR power steering bracket to make it work using your stock lines. I already did this swap so I know from painful experience. LOL!
for power steering go here https://honda-tech.com/forums/showthread.php?t=1822781 that's what i used to figure out which pump i needed and what brackets. All the info is right there. The FAQ section of this forum will pretty much answer all of your questions. Just look for the sticky at the top of the page.
