FS:F23 Short Block, H23 Head, Many More
Old Jan 21, 2009 | 09:54 PM
InvaderTrax's Avatar
Default FS:F23 Short Block, H23 Head, Many More
-F23A3 (SOHC VTEC) block brand new from Honda with 0 miles REDUCED to $400 will make a deal for other parts as a package
-F23Ax Honda head gasket
-H23A1 head use as is or hot tank and rebuild
-F20B aluminum AC bracket weighs less than 2lbs, USDM F/H bracket weighs 8
-4th gen Prelude lower ball joints new
-4th gen Prelude driver outer tie rod new
-H23A1 timing belt and valve cover gasket, new from Honda
Old Jan 21, 2009 | 10:30 PM
KB91Hatch's Avatar
Default Re: FS:F23 Short Block, H23 Head, Many More
how much for the block? 815-600-6499 texting is the easiest way to reach me.
Old Jan 22, 2009 | 04:30 AM
MassScene's Avatar
pm me with a price on the block.
Old Jan 22, 2009 | 05:35 AM
vegeta_man111's Avatar
deff want the block. PM me with prices. Have cash for it in hand depending on price
Old Jan 22, 2009 | 08:43 AM
I'm looking for $500 picked up. If you buy the block and want the H23 head, we can work out a deal. KB91 is first in line, so I'll keep you guys informed
Old Jan 23, 2009 | 10:06 AM
Bump everyone has PM's but only one reply......
Old Jan 24, 2009 | 11:43 PM
I think some of you guys are missing the point on this. Although it's not a complete motor, it's also not pulled from a wreck. It's got zero miles. It's got brand new rings, pistons, rods, bearings, crank, oil pump, and water pump. There's no rebuilding or even freshening up for this thing. Throw your pick of heads on it with a T3 and run 10 PSI all day long (so long as you tune it right). I'll even throw in the head gasket if you buy the block for $500. $600 and I'll throw in the H23 head, which includes a new valve cover gasket. Then all you need is an F22Ax water pipe, intake manifold, and electrical bits and you've got yourself a G23
Old Jan 26, 2009 | 11:08 AM
Bump everything still available
Old Jan 27, 2009 | 10:55 AM
Bump reduced to $400 for the block
Old May 9, 2009 | 03:37 PM
ludemach23's Avatar
H23 head still for sale?
Old Oct 27, 2009 | 10:42 AM
thumper64's Avatar
Still have that F23 block?
Old Oct 27, 2009 | 02:31 PM
94lude_h22a's Avatar
PM me if the f23 is still available
Old Oct 29, 2009 | 03:46 PM
Kidd_Stylez's Avatar
I too am curious if these parts are still avail?
Old Nov 2, 2009 | 08:11 AM
kd97accord's Avatar
How much fer a A/C bracket?
Old Feb 15, 2010 | 10:21 PM
hisnibs's Avatar
PM me if you're interested in shipping the block.
I am looking for a solid base for my F23A turbo build...
B1Integra
Dec 18, 2012 04:31 PM
hotboxnaccord
Nov 29, 2009 02:39 PM
91(si)hatchey
Dec 9, 2006 11:13 AM
tegasaurus
Mar 6, 2006 09:02 AM
