Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
MDX brake Caliper swap
Old Jan 21, 2009 | 08:14 PM
dayaftertomorrow33's Avatar
Default MDX brake Caliper swap
Has anyone tried to swap the 07-08 front caliper to 03-06. I know 07 front caliper is a dual piston while 03-06 are single piston. I have a 00 civic with a dual piston 95 Legend front calipers swapped without any complex modification. Anyone knows it may work the same as the MDX?
Old Jan 22, 2009 | 05:33 AM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: MDX brake Caliper swap
It should work, the hub flange is the same IIRC.
Old Jan 22, 2009 | 09:52 AM
reaction360's Avatar
sooooo... would this work on an '02 odyssey as well? mines about due for some front brakes
Old Jan 22, 2009 | 06:34 PM
Ross 2.0's Avatar
02 odyssey has a different hub bracket.
Old Jan 25, 2009 | 11:59 AM
luciferi's Avatar
01-02 are single piston, the 03-06 mdx are dual piston, same as 05 ody, 07 crv and rdx. The 07 mdx caliper is larger but If I rembember the same bolt spacing. The 01-02 has a different caliper bolt which I think is smaller than 03-09 dual pistons. You will probably need to drill out the spindle.
ody 2 piston on crv
Old Jan 28, 2009 | 05:21 AM
Ross 2.0's Avatar
Did you change the master cylinder too?
emilgonter
Honda CR-V & Element
Jun 2, 2017 10:11 PM
Don Dempsey
Jan 21, 2013 07:28 AM
kidcool1977
Nov 30, 2008 05:42 AM
ibe2fly
32
Jul 7, 2005 04:09 PM
memphiss13
Jan 29, 2003 04:30 PM
