what to do??? i need help H-T.
Old Jan 21, 2009 | 07:37 PM
chaucer's Avatar
Default what to do??? i need help H-T.
hey, everyone. it's sad that everytime that i switch out my old plugs for new ones i always tend to use anti-seize to prevent any possible problems. and just last week, when i was about done replacing all the plugs in, cylinder #1 somehow was hard to screw in and i did use anti-seize and so did all the previous plugs that i installed. and the problem is what do i do when it's my first motor that i bought and it's a jdm type r motor. do i take the head off and take it to a machine shop or do i just get a b16 head and port poslish it? thanks.
Old Jan 21, 2009 | 07:44 PM
sinepome's Avatar
Default Re: what to do??? i need help H-T.
your goinng to have to clear this up.
what are you trying to say?
your spark plug wont screw in?
xci_ed6's Avatar
did you cross thread it?
Old Jan 21, 2009 | 07:50 PM
88efZ6's Avatar
That's what it sounds like to me.
Old Jan 21, 2009 | 08:03 PM
chaucer's Avatar
my bad. what i was trying to explain is that my #1 cylinder is stripped, so i forced screwing in the spark plug. and it doesn't sit all the way in, my wire sits about 1mm above where its suppose to sit. and it's a full jdm type r motor. is there proffesional ways to fix this problem. helicoil came up while i was researching i don't know if it's something that will make me feel better. i'm not bragging but i did spend alot of money for this swap. i don't know if there was too much corroted anti-seize that were still in the cylinder threads or what not.
Old Jan 21, 2009 | 08:12 PM
EF_5150's Avatar
yes they are called helicoil's, its better for you to yank the head off so shavings dont get into the cylinder.
look here
http://www.popularmechanics.com/auto...o/4212608.html
or look up helicoils.
Old Jan 21, 2009 | 08:26 PM
jhammond_82's Avatar
Reject Papi
advanced auto sells a plug adapter. i used one on my sisters accord. its designed to grab the threads and screw itself in, it will stop turning when its in far enough. then just put the spark plug in it itself. i think it sells for like 5 bucks or so, a cheap fix when you need it.
Old Jan 22, 2009 | 09:51 AM
xci_ed6's Avatar
coat a tap in grease and chase the threads, you might be able to save it.
Old Jan 22, 2009 | 12:58 PM
schock3's Avatar
use a magnet to get the shavings its way easier!
Old Jan 22, 2009 | 01:07 PM
xci_ed6's Avatar
yeah, cause magnets work for aluminum
Old Jan 22, 2009 | 01:23 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Sure they do..
And you can get them from Oprah!
http://oprahstore.oprah.com/p-1840-a...signature.aspx
(Umm not really..)
Old Feb 25, 2009 | 07:07 PM
tr0n's Avatar
I think my cylinder #4 is stripped bad. What do you do when it's hosed like that?
Old Feb 25, 2009 | 07:13 PM
ZC DOHC CRX's Avatar
I ROFL'd at that... :p
RecklessEJ
Apr 30, 2012 08:13 PM
wkpmichael
May 17, 2009 08:48 PM
92EG8
Oct 10, 2007 05:46 PM
e_r_i_c_
Sep 20, 2003 08:01 PM
prjctCIVIC
Mar 18, 2003 04:06 AM
