Will 16" x 7.5 offset +46 wheels fit on my 96 ITR?
Old Jan 21, 2009 | 04:22 PM
HONDA_TEG's Avatar
Icon2 Will 16" x 7.5 offset +46 wheels fit on my 96 ITR?
Hi guys, im going to buy a set of rays te-37 wheels 16" x 7.5 offset +46, tires 205/45/16 will they fit good on my HONDA Integra jdm type-r 4 stud 1996? Thanks Guys..
Old Jan 22, 2009 | 11:53 AM
hushypushy's Avatar
Default Re: Will 16" x 7.5 offset +46 wheels fit on my 96 ITR?
They'll fit.
My friend's DC2 had 15x7 +35, which is close to your size, on 205/50/15 and the fitment was great.
Old Jan 22, 2009 | 04:09 PM
nsxtasy's Avatar
H-T Order of Merit
Originally Posted by hushypushy
They'll fit.
You can't conclude from that that they'll fit. Between the 11 mm deeper offset and the extra 6.4 mm of width on either side of the hub, that's almost 3/4" LESS clearance around the inside lip of the wheel. And the difference in offset means almost 1/2" less clearance around the tread of the tire, towards the car. Maybe they will still clear without rubbing, but maybe they won't.
Just because you think something is "close to your size" doesn't mean it's necessarily close enough to fit.
Old Jan 22, 2009 | 08:07 PM
hushypushy's Avatar
Ok, then I revise my answer to: It'll probably fit if you roll your fenders.
Old Jan 23, 2009 | 11:43 AM
Notorious92rhdEG's Avatar
yes they will fit. that is very close to the stock size and offset of the JDM 16in wheels.
Old Jan 23, 2009 | 01:28 PM
01_ITR's Avatar
not to thread jack, but does anyone know if 16x8 with 42mm offset will fit on the ITR while still being pretty low?
Old Jan 23, 2009 | 02:40 PM
thetunersource's Avatar
Yeah, they will fit. But I say with that run some of those old school wheels like MR-5 or R N R Mugen.
Old Jan 23, 2009 | 03:28 PM
nsxtasy's Avatar
H-T Order of Merit
I don't know, but it's an extra inch in width, AND with the higher offset number it's "pushed in" towards the car, so you'll have less room to clear suspension components, etc.
I think it's a bad idea for another reason. On an ITR, you can use either 205/45-16 or 215/45-16 tires. About 80-90 percent of the tires available in those sizes come in 205/45 and not 215/45 (with the Azenis being a notable exception). However, 205/45-16 should NOT be mounted on 16x8 wheels, only on 16x7, so with 16x8 you're ruling out most of the tires you might otherwise use.
All in all, I recommend against it...
EK99hatch
Honda Fit
Nov 14, 2008 05:23 PM
AzN_Flava
Apr 16, 2006 06:35 PM
85mm LS VTEC
Sep 16, 2005 10:14 PM
killaj12
Sep 4, 2005 08:34 AM
vinuneuro
Mar 11, 2004 09:20 PM
