Rosko Racing IACV Relocation Kit (Install and Feedback)
I had contacted Rosko this pass summer for one of his Euro R intake manifolds with EGR block off and IAT and his new IACV (Idle Air Control Valve) Relocation Kit.
My issue was being a swap I needed additional clearance from the firewall. Since the IACV is located on the back of the manifold on the Euro R unlike the reg. H22A manifold. Well his kit worked out perfect for me. I relocated the IACV under the intake manifold with the factory prevision studs and it gave me the necessary clearance I needed. I was very happy to say the least. Now talk about his work he does on the manifold. It's top notch and the parts he uses are straight blingin. Very fair priced I might add.
He also port matched my Throttle Body opening to 68mm Performance Product TB which they fit just like OEM and are similar far as castings and that TPS spacing which we all know on most throttle bodies are spaced way out which sucks for swaps. Not the case with PP just like OEM spacing!
The IACV Relocation Kit I would assume would possibly be needed for the 4th Gens/Civic's and Integras. Definetly the EF chassis! Or just for a cleaner look and relocating.
I spent a lot of time this pass summer with this kit daily driving and on the track. No issues at all!
Just for reference the Euro R intake manifold is about 1/2" shorter then the regular H22A manifold
Great Product! Great Service!
www.RoskoRacing.com
www.RoskoRacing.com
I have some of his products and they are very well made and exreamly well priced. They work and fit like they came from the factory. Keep up the good work Rosko
yea he help me out getting his maninfold to me quick to i can do my build a few months ago and got stop by fiancial family problems but hey everyone is drouling espically cause i got the his rail and entire kit so i can use rdx injectors
I have a customer b series intake manifold...does anyone know if this kit will work...my manifold has no IACV mounting bracket....could the b series iacv fit this relocation kit???
Someone pls PM me with the answer
swfitz2003
Dec 18, 2007 09:34 PM
se93
Nov 15, 2005 01:41 PM
turboed4life
May 15, 2004 12:14 PM
