code 16 after msd installed (fuel system)
after installing msd on my 96 b18, my 93 civic started to miss like crazy when i got on it at high rpm (around 4500 to 6000) it throwing a code16(fuel system). i got 96 obd2 injectoers in it. i didnt cut my wiring harness, a shaved the sides of the injectors where my(95 si harness)would plug up to injectors. i thought that was the problem but i checked all the injectorplugs, and all fit good. by the way i found out my alt is bad today. could that be the problem with the msd needing power to operate? any info would help thanx
civicr97
Feb 26, 2004 08:36 AM
