f/s Hondata s300 p28
has all the options open on it, comes installed in a p28, usb cable, cd, and the box it came in. asking 500 plus shipping or if you have a prb ecu we can work something out. paypal add 3%
thecowisbig@hotmail.com
will have pics up either tonight or tomorrow
Fits inside the ECU
Made in USA
Built on the proven s100/s200 code base
USB connection for speed and compatibility
SManager Windows based software for parameter & table editing, calibration uploading and datalogging.
Real-time updating of ECU
Built in calibrations for common engine combinations
Built in datalogging to a laptop
On board datalogging memory (2 MB memory, 20-60 minutes datalogging)
Adjustment for different sized injectors, with overall fuel trim.
Configurable for any MAP sensor (to at 5 Bar and above)
TPS based table lookup for ITBs
Engine protection from over boost.
Expanded fuel and ignition tables, both in rpm and load, to 60 lbs boost and 11,000 rpm (these are not the upper limits)
Launch control with anti-lag
Full throttle shift
Three multi purpose outputs for nitrous control or similar
Supports lambda tracing from a wideband o2 (PLX wideband recommended)
PWM output for boost control
Dual tables for high/low octane calibrations etc.
Two analog inputs for wideband, EGTs etc.
SManager editing software features:
High and low speed 24 x 20 ignition and fuel tables for correct VTEC tuning
Injector size fuel trim
Fuel trim for starting, throttle tip in and individual cylinder trim
Rev limiter with fuel cut or fuel and ignition cut
Full throttle shift
Adjustable VTEC window with load and throttle control
Secondary intake runner control
Adjustable idle speed
MAP sensor type and calibration
Adjustable boost cut with hot and cold settings
Shift light
Closed loop control
Air temperature compensation
Water temperature compensation
Fuel and ignition correction based on gear
A/C shutoff conditions
Closed loop
Three general purpose outputs for nitrous control, quad boost control or similar
On board datalogging trigger conditions
The s300 uses different connecting pins in the ECU from the s100/s200, and also has a slot cut in the side for the USB connector, so the ECU must be modified for use with the s300. The s300 is made to fit in a full frame ECU case (US and most markets), so will not fit in a JDM ECU case.
Fits inside the ECU
Made in USA
Full throttle shift
Full throttle shift
Shift light
Closed loop control
Closed loop
JDMlyfestyle
Oct 9, 2005 11:09 AM
