car wont go into gears?
i was driving my car home from work today, after driving about 5 min i couldn't put car into gears. i can step on the clutch but it wont allow me to go up or down. i park it and turn off the engine and play around with it and still wouldn't grab. i drive a 95 Ls with 130xxx on the clock, could it be my shift link is broken? anyone ever experience this problem?
see if there is fluid leaking near the top of your clutch pedal inside the driver footwell. chances are your clutch master blew out...look under hood to see if any clutch fluid in reservoir; check slave cyl on front of trans to see if leaking as well. that's what happened if you are lucky, but your clutch may be just gone. good luck sir
no leaks at all, my reservoir, slave and master cylinder is fine. i cannot put it into first or any of the gears. when i step on the clutch pedal everything seems like its working fine, i just cant put it into gears even when the clutch is step down
deeweezy187
Feb 26, 2008 01:20 PM
