need help b20 swap on 89 crx wiring no wont start
Old Jan 21, 2009 | 12:01 AM
newtype_racing's Avatar
Default need help b20 swap on 89 crx wiring no wont start
did a b20 swap on 89 crx,replaced whole wiring harness with obd0 si harness now i cant get it start.fuel system and ignition system had been check and seems to be working.
Old Jan 21, 2009 | 12:11 AM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: need help b20 swap on 89 crx wiring no wont start
What codes are you throwing if any?
you have... spark, fuel, compression?
any sputtering or just nothing?
Old Jan 21, 2009 | 12:50 AM
i havent install my dash yet yes i have spark,fuel and comp.
Old Jan 21, 2009 | 08:57 AM
93formula's Avatar
??? what do you mean you havent installed your dash? was your car originally an si?
Old Jan 21, 2009 | 08:59 AM
h224thgensedan's Avatar
All Grounds good.
Old Jan 21, 2009 | 05:16 PM
all grounds good the car use to be ef.it will crank but it wont start.
Old Jan 21, 2009 | 07:11 PM
K why did you replace the harness.
Old Jan 21, 2009 | 07:41 PM
the old engine is carburator and im planning on going b20 vtec later.
Old Jan 21, 2009 | 07:56 PM
88efZ6's Avatar
Did you replace the entire interior harness to because if you didn't your still missing a few wires.
Old Jan 21, 2009 | 08:53 PM
Twisted Image's Avatar
ummmm. an 89 CRX should not have had a Carb. if it did you have problems.
All CRX's are Ef's 88-91
The SI and DX harness are difrent and will not plu and play
If you had something besides an SI you need to read how to do a MPFI swap in the FAQ section.
Old Jan 22, 2009 | 03:53 PM
i replaced the whole wiring harness all the way to the ecu and dash.
Old Mar 1, 2009 | 05:58 PM
Blue-EM1's Avatar
worth a shot see if itll run on carb cleaner...if you have spark and fuel its got to start. make sure you removed the resistor box correctly, cuz if not your injectors wont fire-
Old Mar 1, 2009 | 08:22 PM
93formula's Avatar
what dist are you using?
newtype_racing
Dec 15, 2008 03:57 PM
B18C1_CRX
Jul 15, 2006 03:35 PM
Blue-EM1
Jul 5, 2006 07:15 PM
austincrx
Jul 1, 2006 06:28 PM
91civichatchCrX
Mar 25, 2005 08:43 PM
